16 mm on/off led switch wiring diagram
by kpurzycki on Thu Apr 12, 2018 11:54 am
I just received the 16 mm LED switch (PN 1442A). It did not come with wiring details: I get + and-, but how do I wire the LED to be lit when activated and unlit when off? which terminal do I attach the resistor?
kpurzycki
Re: 16 mm on/off led switch wiring diagram
by adafruit_support_carter on Thu Apr 12, 2018 11:59 am
Just treat it like a normal LED, with the + being the anode / long leg and the - being the cathode / short leg. Same applies for locating the current limiting resistor.
by kpurzycki on Thu Apr 12, 2018 1:15 pm
A simple on off has only 2 lugs this switch has 4 2 log 2 short can you simply send me a simple wiring diagram as Adafruit usually does with what ever they sell on how to wire it correctl
kpurzycki
by adafruit_support_carter on Thu Apr 12, 2018 1:28 pm
The + and - pins are labeled on the back of the button:
https://cdn-shop.adafruit.com/1200x900/1442-04.jpg
Those two pins are the LED.
The other two pins are the button switch (like a normal on off has)
by paulfecht on Fri Apr 13, 2018 10:39 am
Hi there, purchased the latching Blue LED on/off switch. Going to be turning on and off my 12v robot with it.
Hints, tips, tricks, wiring diagrams for doing so and not blowing the LED.....?
I'm considering putting a 1Kohm resistor in series with the LED... will that work.
A simple wiring diagram considering a 12v DC power supply would be greatly appreciated.
I'm assuming the LED uses around 3.3V and the switch is connecting 12v. Will the resistor
take care of this?
Thank you
paulfecht
by adafruit_support_carter on Fri Apr 13, 2018 11:14 am
@paulfecht Please start a new thread for your questions.
