NeoPixel Jewel Lib Wrong Colors
by vl_martin on Sat Apr 14, 2018 7:45 am
I've connected a NeoPixel Jewel to a Trinket M0 and used the example jewel-hair-stick to test it, but the library fails - it doesn't produce the correct colors, overlaps the pixels if I use setPixelColor... If I define 7 as the number of pixels to use the last pixel is always off.
I've played around a bit and it seems that it doesn't really forward the colors correctly, only pixel 0 is working correctly (if I decide to only use that pixel). I used the following code to test the jewel, uploaded screenshots too:
#define PIN 4
#define NUMPIXELS 7
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
uint32_t test [] = {
  strip.Color(255,   0,  0),
  strip.Color(  0, 255,  0),
  strip.Color(  0,   0,255)};
  strip.begin();
  strip.setBrightness(30);
  strip.show(); // Initialize all pixels to 'off'
int i, j = 0;
void loop()
  for (i = 0; i < NUMPIXELS; i++)
    strip.setPixelColor(i, test [j]);
  j++;
  if (j >= 3)
    j = 0;
  strip.show();
  delay(3000);
photos of each step:
https://ibb.co/hsxBmn
https://ibb.co/h6mtz7
https://ibb.co/nRkQCS
Am I missing something here?
vl_martin
Re: NeoPixel Jewel Lib Wrong Colors
by adafruit_support_bill on Sat Apr 14, 2018 9:46 am
Looks like you may have one of the RGBW jewels. In that case, you need to change
to
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRBW + NEO_KHZ800);
by vl_martin on Sat Apr 14, 2018 2:46 pm
my very bad - should have known better ... did the trick - thanks a lot !
vl_martin
by adafruit_support_bill on Sat Apr 14, 2018 3:15 pm
Good to hear it is working. Thanks for the follow-up.
