Pin 8 Backlight on 3.5" Color TFT Touchscreen
- Steve44
Can you tell me if Pin 8 of the 320x480 8-Bit connector is supposed to be connected? I can't find it mentioned in the docs. -Thanks
- adafruit_support_carter
Re: Pin 8 Backlight on 3.5" Color TFT Touchscreen
Are you working with this product?
https://www.adafruit.com/product/2050
And are you trying to use it in 8-bit mode?
https://learn.adafruit.com/adafruit-3-5 ... 8-bit-mode
I'm not sure what you mean by "pin 8 backlight".
- Steve44
OK thanks I couldn't find a ref to it in my docs. It is pin 8 of the 8 bit header, marked 'Backlite'. I see it is either not connected or connected to a PWM channel. Thanks-
