I am currently working on my final assessments together with a study partner.
We are trying to figure out how we can make NeoPixels 'breathe' while having them all soldered in a row.
For now we are only building a 'proof of concept' meaning we are currently working on our maquette.
Seeing as we aren't really technical when it comes to using Arduino we hope there is someone out there that could help us out.
Our project is about visualising movement / life at cultural hotspots (museums, concert halls and so on).
We have separated different types of culture, leading to five different colours (Purple, Green, Blue, Red and Yellow/Orange)
Currently we got all the lights 'breathing' at the same time where we would ideally love to have each individual light breathe in a slightly staggered manner (not all at the same time).
The strange thing aswell is when we have got the lights breathing at the same time in the current code, Yellow / Orange turns to red.
Also we seem to be unable to have all the lights breathe and have the text 'this is culture' as a solid white color as it will only breathe along with the text or turn off all together.
Added will be some pictures of the setup and the main code currently running.
We really hope there is someone out there able to help us out!
Thanks in advance!
Martijn
// put your setup code here, to run once:
#define PIN 6
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(26, PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel neo = Adafruit_NeoPixel(26, PIN, NEO_GRB + NEO_KHZ800);
strip.begin();
strip.setBrightness(255); // Lower brightness and save eyeballs!
strip.show(); // Initialize all pixels to 'off'
void culture() {
neo.begin();
neo.setBrightness(255); // Lower brightness and save eyeballs!
neo.show(); // Initialize all pixels to 'off
neo.setPixelColor(22, 255, 255, 255); //TEXT / White
neo.show();
neo.setPixelColor(23, 255, 255, 255); //TEXT / White
neo.show();
neo.setPixelColor(24, 255, 255, 255); //TEXT / White
neo.show();
neo.setPixelColor(25, 255, 255, 255); //TEXT / White
neo.show();
// put your main code here, to run repeatedly:
a
for (int i=10; i<255; i++) {
strip.setBrightness(i); strip.show(); delay(5); } //breathe
for (int i=255; i>10; i--) {
strip.setBrightness(i); strip.show(); delay(8); } //breathe
strip.setPixelColor(0, 255, 0 , 255); //PopEI / Purple
strip.show();
strip.setPixelColor(1, 0, 255, 0); //Area 51 / Green
strip.show();
strip.setPixelColor(2, 0, 0, 255); //NatLab / Blue
strip.show();
strip.setPixelColor(3, 0, 0, 255); //MU / Blue
strip.show();
strip.setPixelColor(4, 255, 0, 25); //De Ontdekfabriek / Red
strip.show();
strip.setPixelColor(5, 255, 0, 255); //Carte Blanche / Purple
strip.show();
strip.setPixelColor(6, 255, 0, 25); //CKE / Red
strip.show();
strip.setPixelColor(7, 255, 0, 255); //Stroomhuis / Purple
strip.show();
strip.setPixelColor(8, 0, 0, 255); //Zwarte Doos / Blue
strip.show();
strip.setPixelColor(9, 255, 135, 0); //Van Piere / Yellow
strip.show();
strip.setPixelColor(10, 255, 0, 255); //Muziekgebouw / Purple
strip.show();
strip.setPixelColor(11, 255, 0, 255); //Effenaar / Purple
strip.show();
strip.setPixelColor(12, 255, 0, 255); //Afslag Eindhoven / Purple
strip.show();
strip.setPixelColor(13, 255, 135, 0); //DAF Museum / Yellow
strip.show();
strip.setPixelColor(14, 255, 0, 255); //Dynamo / Purple
strip.show();
strip.setPixelColor(15, 0, 0, 255); //Van Abbemuseum / Blue
strip.show();
strip.setPixelColor(16, 255, 0, 255); //Parktheater / Purple
strip.show();
strip.setPixelColor(17, 255, 0, 25); //Prehistorisch Dorp / Red
strip.show();
strip.setPixelColor(18, 0, 0, 255); //De Kazerne / Blue
strip.show();
strip.setPixelColor(19, 255, 20, 0); //Philips Museum / Yellow
strip.show();
strip.setPixelColor(20, 255, 135, 0); //Bibliotheek Eindhoven / Yellow
strip.show();
strip.setPixelColor(21, 255, 135, 0); //Onomatopee / Yellow
strip.show();
