2.2" 18-BIT COLOR TFT LCD persistent white screen
Re: 2.2" 18-BIT COLOR TFT LCD persistent white screen
by That_one_guy on Sun Sep 08, 2019 9:51 am
I had a similar issue with my display that I just received. My display (the 2.2" TFT Display
320x240 pixels in 18 bit color with a microSD breakout) would randomly display a white screen, and I would have to reset my Arduino Mega a few times or reprogram it for it to work again. It would only function for a few minutes at most after this before the screen went white again. My serial interface was still printing information so my Arduino was still running correctly. I found that connecting the RST pin of the display breakout board directly to the Arduino 3.3V rail (and leaving it connected) fixed the problem.
That_one_guy
by jadeparade on Mon Nov 11, 2019 7:10 pm
I've been struggling with this issue for an hour and this did the trick for me. I went from RST to RST on the Metro board with this display, and now it's displaying the entire test. Thank you!
jadeparade
by adafruit_support_carter on Thu Nov 14, 2019 1:08 pm
Sounds like maybe an issue with a floating RST line? Does it also solve the issue if you wire up RST to an available GPIO and then provide that when setting up the display:
https://github.com/adafruit/Adafruit_IL ... st.ino#L28
by waltr on Sat Jan 04, 2020 11:51 pm
Interesting point about the RESET.
I recently got the 2.8" TFT breakout and did not connect the RESET line as per the Manual. Only had a white screen.
So connected the RESET and ensured my code Toogled low then held REST high and the display worked.
Since I do much electronics and pay attention to pins like RESET and the timing connecting and handling RESET timing in code makes sense.
waltr
