LED Matrix Sand Toy
LED Matrix Sand Toy
by Jwylie01 on Mon Jun 25, 2018 8:39 pm
I just finished assembling the LED sand toy and everything works great except for the fact it thinks up is down. All the “sand” rush to the top when the demo starts. Any ideas what could be the issue? The board can only be mounted on the holder one way so don’t think that’s the issue.
Jwylie01
Re: LED Matrix Sand Toy
by Jwylie01 on Tue Jun 26, 2018 7:11 am
I fixed it. Made some changes to the code for all the demos and it works correctly now
Jwylie01
by hagent on Sun Jan 13, 2019 5:13 pm
This project is really sweet! I had some trouble at first, I'm using a Pi Zero W. When I selected the "solder" option during the install process, I couldn't get the display to work. The instructions for the solder option tell you to solder GPIO4 and GPIO18 pins together on the Bonnet. I don't think Pi Zero's have a GPIO18. The setup worked fine when I selected the "non-solder" option.
hagent
by mmkaiser on Mon Feb 25, 2019 9:32 pm
Can you tell me what changes you made to your code, because I am having the same issue and cannot figure out what to do. Thanks!!
mmkaiser
by adafruit_support_carter on Mon Feb 25, 2019 9:49 pm
Is this happening with everything orientated per the build?
https://cdn-learn.adafruit.com/assets/a ... 1519613457
It sounds like a 180deg rotation of the LIS3DH is somehow happening. Either it is being mounted rotated or the code doesn't match the guide.
