Input driver version is 1.0.1
Input device ID: bus 0x18 vendor 0x0 product 0x0 version 0x0
Input device name: "stmpe-ts"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 330 (BTN_TOUCH)
Event type 3 (EV_ABS)
Event code 0 (ABS_X)
Value 1772
Min 0
Max 4095
Event code 1 (ABS_Y)
Value 48
Min 0
Max 4095
Event code 24 (ABS_PRESSURE)
Value 0
Min 0
Max 255
Properties:
Testing ... (interrupt to exit)
Event: time 1531863199.596813, type 3 (EV_ABS), code 1 (ABS_Y), value 33
Event: time 1531863199.596813, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 1
Event: time 1531863199.596813, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1531863199.596813, -------------- SYN_REPORT ------------
Event: time 1531863199.660634, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 0
Event: time 1531863199.660634, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1531863199.660634, -------------- SYN_REPORT ------------
Event: time 1531863199.766896, type 3 (EV_ABS), code 0 (ABS_X), value 1773
Event: time 1531863199.766896, type 3 (EV_ABS), code 1 (ABS_Y), value 45
Event: time 1531863199.766896, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 1
Event: time 1531863199.766896, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1531863199.766896, -------------- SYN_REPORT ------------
Event: time 1531863199.830841, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 0
Event: time 1531863199.830841, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1531863199.830841, -------------- SYN_REPORT ------------
Event: time 1531863210.953657, type 3 (EV_ABS), code 0 (ABS_X), value 1774
Event: time 1531863210.953657, type 3 (EV_ABS), code 1 (ABS_Y), value 13
Event: time 1531863210.953657, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1531863210.953657, -------------- SYN_REPORT ------------
Event: time 1531863211.020953, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1531863211.020953, -------------- SYN_REPORT ------------
Event: time 1531863212.131318, type 3 (EV_ABS), code 0 (ABS_X), value 1781
Event: time 1531863212.131318, type 3 (EV_ABS), code 1 (ABS_Y), value 28
Event: time 1531863212.131318, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1531863212.131318, -------------- SYN_REPORT ------------
Event: time 1531863212.200819, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1531863212.200819, -------------- SYN_REPORT ------------
Event: time 1531863216.332463, type 3 (EV_ABS), code 0 (ABS_X), value 1767
Event: time 1531863216.332463, type 3 (EV_ABS), code 1 (ABS_Y), value 10
Event: time 1531863216.332463, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1531863216.332463, -------------- SYN_REPORT ------------
Event: time 1531863216.400861, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1531863216.400861, -------------- SYN_REPORT ------------
Event: time 1531863216.902890, type 3 (EV_ABS), code 0 (ABS_X), value 1786
Event: time 1531863216.902890, type 3 (EV_ABS), code 1 (ABS_Y), value 149
Event: time 1531863216.902890, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1531863216.902890, -------------- SYN_REPORT ------------
Event: time 1531863216.970815, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1531863216.970815, -------------- SYN_REPORT ------------
Event: time 1531863217.160522, type 3 (EV_ABS), code 1 (ABS_Y), value 48
Event: time 1531863217.160522, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 1
Event: time 1531863217.160522, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1531863217.160522, -------------- SYN_REPORT ------------
Event: time 1531863217.230857, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 0
Event: time 1531863217.230857, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1531863217.230857, -------------- SYN_REPORT ------------
Event: time 1531863222.338859, type 3 (EV_ABS), code 0 (ABS_X), value 1774
Event: time 1531863222.338859, type 3 (EV_ABS), code 1 (ABS_Y), value 314
Event: time 1531863222.338859, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 20
Event: time 1531863222.338859, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1531863222.338859, -------------- SYN_REPORT ------------
Event: time 1531863222.400671, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 0
Event: time 1531863222.400671, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1531863222.400671, -------------- SYN_REPORT ------------
Event: time 1531863229.484991, type 3 (EV_ABS), code 0 (ABS_X), value 1792
Event: time 1531863229.484991, type 3 (EV_ABS), code 1 (ABS_Y), value 47
Event: time 1531863229.484991, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 7
Event: time 1531863229.484991, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1531863229.484991, -------------- SYN_REPORT ------------
Event: time 1531863229.550651, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 0
Event: time 1531863229.550651, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1531863229.550651, -------------- SYN_REPORT ------------
Event: time 1531863231.910013, type 3 (EV_ABS), code 0 (ABS_X), value 1772
Event: time 1531863231.910013, type 3 (EV_ABS), code 1 (ABS_Y), value 37
Event: time 1531863231.910013, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 11
Event: time 1531863231.910013, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1531863231.910013, -------------- SYN_REPORT ------------
Event: time 1531863231.970730, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 0
Event: time 1531863231.970730, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1531863231.970730, -------------- SYN_REPORT ------------
Event: time 1531863232.159637, type 3 (EV_ABS), code 0 (ABS_X), value 1778
Event: time 1531863232.159637, type 3 (EV_ABS), code 1 (ABS_Y), value 128
Event: time 1531863232.159637, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 29
Event: time 1531863232.159637, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1531863232.159637, -------------- SYN_REPORT ------------
Event: time 1531863232.220902, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 0
Event: time 1531863232.220902, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1531863232.220902, -------------- SYN_REPORT ------------
Event: time 1531863236.155805, type 3 (EV_ABS), code 0 (ABS_X), value 1798
Event: time 1531863236.155805, type 3 (EV_ABS), code 1 (ABS_Y), value 15
Event: time 1531863236.155805, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 1
Event: time 1531863236.155805, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1531863236.155805, -------------- SYN_REPORT ------------
Event: time 1531863236.164669, type 3 (EV_ABS), code 0 (ABS_X), value 1794
Event: time 1531863236.164669, type 3 (EV_ABS), code 1 (ABS_Y), value 18
Event: time 1531863236.164669, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 3
Event: time 1531863236.164669, -------------- SYN_REPORT ------------
Event: time 1531863236.231490, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 0
Event: time 1531863236.231490, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1531863236.231490, -------------- SYN_REPORT ------------
Event: time 1531863238.266383, type 3 (EV_ABS), code 0 (ABS_X), value 1776
Event: time 1531863238.266383, type 3 (EV_ABS), code 1 (ABS_Y), value 140
Event: time 1531863238.266383, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 3
Event: time 1531863238.266383, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1531863238.266383, -------------- SYN_REPORT ------------
Event: time 1531863238.330827, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 0
Event: time 1531863238.330827, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1531863238.330827, -------------- SYN_REPORT ------------
