Is it possible to change what an Arduino is running without reprogramming it? So if I wanted to change which monitor my Adalight was grabbing?
My thought is that I could stream my Xbox to my PC monitor (I use my PC as a media center/gaming/machine) and have Adalight, which would normally grab my TV, switch and grab the stream on the other monitor instead and thus work with my Xbone.
I think that makes sense.
Switch Arduino program on the fly?
- dnorm
Re: Switch Arduino program on the fly?
Or maybe I am overthinking things. Could I just have the Arduino change a variable, or read a variable from my PC over the USB?
You would need to combine the two programs into one - with a conditional statement such as an 'if' to switch between them.
You could connect a switch to one of the GPIO pins. Or you could send a command via the USB Serial connection to your PC and use that as the condition of your 'if' statement.
- dnorm
Okay thanks!adafruit_support_bill wrote:You would need to combine the two programs into one - with a conditional statement such as an 'if' to switch between them.
