Supernova poi
Supernova poi
by Steveajb on Mon Jul 23, 2018 4:55 pm
I have built the Supernova Poi it is working but for the life of me I cannot get the convert.py to run,
I tried it on a linux (Ubuntu) machine, a windows 10 laptop and a macbook without any success.
It always stops at line 141 with a syntax error see following text:
C:\Python34\convert>python convert2.py images/*.jpg > graphics.h
File "convert2.py", line 141
print "// Don't edit this file! It's software-generated."
SyntaxError: Missing parentheses in call to 'print'. Did you mean print("// Don't edit this file! It's software-generated.")?
Any help would be welcomed
Help
Steveajb
Re: Supernova poi
by Agundel on Fri Oct 26, 2018 3:25 pm
Hi I think its only works with bmp or gif.
Agundel
Re: Supernova poi
by RowdyDy on Mon Jan 14, 2019 7:28 pm
I have the same problem could you tell me if you got the solution please
File "convert.py", line 141
falla convert.jpg (93.21 KiB) Viewed 94 times
RowdyDy
Re: Supernova poi
by adafruit_support_carter on Wed Jan 16, 2019 2:26 pm
The program appears to be Python 2 only. It won't run with Python 3.
Re: Supernova poi
by RowdyDy on Sun Jan 20, 2019 12:51 am
adafruit_support_carter wrote:The program appears to be Python 2 only. It won't run with Python 3.
ok muchas gracias solo una pregunta para python 2 es con la libreria PIL o seria Pilllow gracias
RowdyDy
Re: Supernova poi
by adafruit_support_carter on Mon Jan 21, 2019 1:57 pm
Probably PIL.
Re: Supernova poi
by RowdyDy on Mon Jan 21, 2019 2:53 pm
adafruit_support_carter wrote:Probably PIL.
muchas gracias lo logre despues de muchisimos intentos fallidos y lo que hice fue instalar python 3 y tambien instale anaconda navigator y ehi instale la libreria PIL 1.1.7 y anaconda navigator solo me dio la opcion de transformar python 3 a python 2.7 y ya de ahi quedo configurado ya solo en win10 inicie como administrador y segui la ruta y listo muchas gracias
RowdyDy
