Hello!
The new Adafruit NeoPixel UV LED Strip with 32 LED/m (https://www.adafruit.com/product/3851) looks really cool. Maybe I'm blind, but I don't find specs for the UV LEDs! Could you add some or provide some info here? I am mainly interested in the wavelength/spectrum those LEDs emit at (are they 3 individual ones with different or same wavelengths?).
UV NeoPixel LED Strip - specs
- adafruit2
Re: UV NeoPixel LED Strip - specs
all three dies are going to be the same wavelength, should be 400nm!
- HorstO
Thanks! If there is any way to know for sure I would really appreciate that. I want to use those in a laboratory setting and would like to be able to report accurately. Wavelength/Intensity plots would be perfect.
- adafruit2
we'll try but...these arent calibrated UV LEDs, they'll probably vary anyways. for lab settings we recommend getting binned/calibrated UV emitters from digikey.com
- HorstO
Thanks, good to know! Experiments wouldn't crucially depend on wavelength in this case, it would just give me peace of mind to know more details about their spectra. But I will keep that in mind!
- Plusx
I am also interested in information as to the wavelength. My application would be for possibly using it in a light source for alt process photography, for example platinum/palladium printing. The ability to control brightness in sections could be useful.
- adafruit2
ok UV led datasheet added to https://www.adafruit.com/product/3851
- HorstO
Perfect! Thanks a lot!
- daijetmiu
I see that you have UV NeoPixel now with 395nm UV LED ( https://www.adafruit.com/product/3851 ), will you have a 365nm version soon?
