HX8357D Backlight
adamr1
HX8357D Backlight
Post by adamr1 »
Hello. I am using the HX8357D 3.5" TFT. I am having trouble using the lite pin. What I am trying to do is have the screen light turn off after inactivity (screen not pressed). My code works, and I am using a digitalWrite LOW to disable the backlight but when I turn it back on, its as if the display hangs and you cannot write to the screen anymore. I have tried both digitalWrite and analogWrite with different pins and I get the same result. I am using a MEGA. Is there anything specific to do after the backlight turns back on?
adafruit_support_carter
Re: HX8357D Backlight
Post the complete code listing for the sketch you are running.
adamr1
Post by adamr1 »
I have this:
void tft_liteToggle(boolean i) {
  if(i) {analogWrite(46,255);} else {analogWrite(46,0);}
I've also tried with digitalWrite HIGH/LOW. What I did find is after I do the above, if I do a tft.begin(HX8357D) it works as expected so not sure but that fixes it. And after that, the last screen I had up when I turned the backlight off is there, so its not as if it resets the whole tft, it somehow fixes the problem...
Controlling the backlight should not affect the display. You can use digitalWrite to turn the backlight on/off or analogWrite to PWM to control brightness. Post complete code for the entire sketch.
