pi@raspberrypi:~ $ wget
https://raw.githubusercontent.com/adafr ... t-pitft.sh
--2018-10-01 00:49:36--
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.52.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.52.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 19319 (19K) [text/plain]
Saving to: ‘adafruit-pitft.sh’
adafruit-pitft.sh 100%[=============================================================================>] 18.87K --.-KB/s in 0.05s
2018-10-01 00:49:37 (369 KB/s) - ‘adafruit-pitft.sh’ saved [19319/19319]
pi@raspberrypi:~ $ chmod +x adafruit-pitft.sh
pi@raspberrypi:~ $ sudo ./adafruit-pitft.sh
This script downloads and installs
PiTFT Support using userspace touch
controls and a DTO for display drawing.
one of several configuration files.
Run time of up to 5 minutes. Reboot required!
Select configuration:
1. PiTFT 2.4", 2.8" or 3.2" resistive (240x320)
2. PiTFT 2.2" no touch (240x320)
3. PiTFT 2.8" capacitive touch (240x320)
4. PiTFT 3.5" resistive touch (320x480)
5. Quit without installing
SELECT 1-5: 4
Select rotation:
1. 90 degrees (landscape)
2. 180 degrees (portait)
3. 270 degrees (landscape)
4. 0 degrees (portait)
SELECT 1-4: 1
[PITFT] Checking init system...
Found systemd
/boot is mounted
[PITFT] System update
Updating apt indexes...
Reading package lists...
[PITFT] Installing Python libraries & Software...
Installing Pre-requisite Software...This may take a few minutes!
[PITFT] Updating /boot/config.txt...
[PITFT] Updating SysFS rules for Touchscreen...
[PITFT] Updating TSLib default calibration...
Would you like the console to appear on the PiTFT display? [y/n] n
[PITFT] Making sure console doesn't use PiTFT
Removing console fbcon map from /boot/cmdline.txt
Screen blanking time reset to 10 minutes
Would you like the HDMI display to mirror to the PiTFT display? [y/n] y
[PITFT] Adding FBCP support...
Installing cmake...
W: --force-yes is deprecated, use one of the options starting with --allow instead.
Downloading rpi-fbcp...
Uncompressing rpi-fbcp...
Building rpi-fbcp...
Installing rpi-fbcp...
Remove fbcp from /etc/rc.local, if it's there...
We have systemd, so install fbcp systemd unit...
Created symlink /etc/systemd/system/multi-user.target.wants/fbcp.service → /etc/systemd/system/fbcp.service.
Setting raspi-config to boot to desktop w/o login...
Created symlink /etc/systemd/system/default.target → /lib/systemd/system/graphical.target.
Configuring boot/config.txt for forced HDMI
Using x1.5 resolution
[PITFT] Updating X11 default calibration...
[PITFT] Success!
Settings take effect on next boot.
REBOOT NOW? [y/N] n
Exiting without reboot.
pi@raspberrypi:~ $ sudo shutdown -h now
