Hi Adafruit.. i would like to ask.. Between ( Green 7-segment clock display - 1.2" digit height )
& ( Yellow 7-segment clock display - 1.2" digit height ) . Which is more bright ?
Re: 7-segment clock display
Generally the human eye is most sensitive to wavelengths of around 555 nanometers which is squarely in the green part of the spectrum. So although both displays have similar power output, the green will appear slightly brighter in most circumstances.
- wanekbest
Thanks for reply.. i need a favor from you. Any idea for DP3 & DP4 shorting to pin 11 & pin 12 ( C , B ) because need to run speedometer .
Example : 100 Km/h
Example : 100 Km/h
Not sure what you are attempting to do there. DP3 and DP4 are internally connected in the display module. They can't be controlled individually. The pair is controlled by pins 2 and 24 of the HT16K33 driver chip on the board.
https://cdn-learn.adafruit.com/assets/a ... 1476209216
