Neopixel Driver
Neopixel Driver
by Beatrice94 on Fri Sep 14, 2018 6:17 am
Hi all,
I odered some NeoPixels (through hole LEDs 5mm diffused) for a master thesis project, and I would need to know which version of the driver (SK6812 or WS2812) are using, as the emitted wavelengths are slightly different and I need to compensate for some photodiodes efficiency.
Is there a way I can do this?
Thank you very much
Beatrice94
Re: Neopixel Driver
by adafruit_support_carter on Fri Sep 14, 2018 2:19 pm
Is your concern the slight difference in the LED characteristics between the two datasheets?
Re: Neopixel Driver
by Beatrice94 on Sat Sep 15, 2018 4:27 am
Well, it might be, depending on the calibration procedure I am trying to set up. But that depends also on my advisor. In the meanwhile it is better if I can have the most precise data possible.
Beatrice94
