Neopixel Doesn't work when changing codes
by Erit1566 on Sun Sep 23, 2018 2:27 pm
Hello, I have 2 neopixel rings hooked up to an arduino nano. I have 2 different codes, the example sketch, and the code i am trying to implement it. When I put the example code, Copy paste, into the new code, no leds light.
Here is the first example code:
// NeoPixel Ring simple sketch (c) 2013 Shae Erisson
// released under the GPLv3 license to match the rest of the AdaFruit NeoPixel library
#ifdef __AVR__
  #include <avr/power.h>
#endif
// Which pin on the Arduino is connected to the Neobig?
// On a Trinket or Gemma we suggest changing this to 1
#define bigPIN            11
#define smallPIN            12
// How many Neobig are attached to the Arduino?
#define NUMbig      24
// When we setup the NeoPixel library, we tell it how many big, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel big = Adafruit_NeoPixel(NUMbig, bigPIN, NEO_GRBW + NEO_KHZ800);
Adafruit_NeoPixel small = Adafruit_NeoPixel(NUMbig, smallPIN, NEO_GRB + NEO_KHZ800);
int delayval = 50; // delay for half a second
  // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
//#if defined (__AVR_ATtiny85_ _)
//  if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
//#endif
  // End of trinket special code
  big.begin(); // This initializes the NeoPixel library.
  small.begin();
  // For a set of Neobig the first NeoPixel is 0, second is 1, all the way up to the count of big minus one.
  for(int i=0;i<NUMbig;i++){
    // big.Color takes RGB values, from 0,0,0 up to 255,255,255
    big.setPixelColor(i, big.Color(0,10,0)); // Moderately bright green color.
    small.setPixelColor(i, big.Color(0,0,10));
    big.show(); // This sends the updated small color to the hardware.
    small.show();
    delay(delayval); // Delay for a period of time (in milliseconds).
Here is the code I am trying to implement it
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#ifdef __AVR__
#endif
#define bigPIN  11
#define smallPIN  12
#define NUMbig      48
#define NUMsmall       48
#define BRIGHTNESS 50
Adafruit_NeoPixel small = Adafruit_NeoPixel(NUMsmall, smallPIN, NEO_GRB + NEO_KHZ800);
 int counter = 0;
char t[10]={};
const byte SLAVE_ADDRESS = 8;
int selectPin = 3;
int lastValue1 = 0;
int arrays[128];
long encval;
bool oldState = HIGH;
int casario;
int cased;
int cases;
int pbr;
int pbg;
int pbb;
int psr;
int psg;
int psb;
int x = 0;
int createdEnc = 0;
int nowEnc = 0;
void setup()   {
  delay(500);
  Serial.begin(9600);
  Serial.println("Starting Setup");
  Serial.println("Setting Up Pins");
  Wire.begin(SLAVE_ADDRESS);
  Serial.print("=");
  pinMode(selectPin,INPUT_PULLUP);
  Serial.print("=");
//  pinMode(clearPin,INPUT_PULLUP);
//  Serial.print("=");
//  attachInterrupt(digitalPinToInterrupt(clearPin),Clear,HIGH);
  Serial.println("Finished Setting Up Pins");
  Serial.println("Starting Screen");
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  delay(500);
  // Clear the buffer.
  display.clearDisplay();
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.print("Starting Up");
  display.display();
  delay(500);
  Serial.println("Finished setting up screen");
  #if defined (__AVR_ATtiny85__)
#endif
  Serial.println("Starting Setting up LEDS");
//  small.setBrightness(BRIGHTNESS);
//  big.setBrightness(BRIGHTNESS);
  big.begin();
  small.begin();
  big.show();
  small.show();
  Serial.println("Finished Setting Up LEDS");
  Serial.println("Finished Setup");
//  cross(255,0,0,50);
//  cross(0,0,0,50);
//  display.display();
//  eyes();
//  encRes();
void loop(){
// selection();
//  picker();
  //averageRGB();
// requestEncoder();
  for(int i=0;i<48;i++){
    // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
    small.setPixelColor(i, small.Color(0,0,10));
    big.show(); // This sends the updated pixel color to the hardware.
    small.show();
    delay(50);
I know my code is horrible, I will comment it and everything when I am done with figuring it all out. I'm open to all suggestions. Thanks for all of your help.
-Eric
Erit1566
Re: Neopixel Doesn't work when changing codes
by franklin97355 on Sun Sep 23, 2018 8:05 pm
#define bigPIN  11
#define smallPIN  12
These pins are used by SPI. You should pick some other pins for these.
franklin97355
by Erit1566 on Sun Sep 23, 2018 8:59 pm
I switched them them to pin 6 and 7. On the simple code it both work fine but on the main code the small led ring is now working but the large one is still not.
Erit1566
