I am trying to use an odroid SBC to control a DotStar led strip over SPI.
I used the raw_write function found in the adafruit github library Adafruit_DotStar_Pi as an example, and created a minimal c function that writes out an array to the DotStar strip.
I tested this function on a Pi with success, but when I ported the code over to the odroid it didn't work. To debug, I shorted MOSI to MISO and could see that the message was in fact being sent...
Has anyone experienced the same problem, or maybe know a solution? I could provide my code sample if needed; the only difference between the code on the odroid and the pi is which header libraries are invoked
Using DotStar LED Strip on Odroid
- Franklin97355
Re: Using DotStar LED Strip on Odroid
Check out the odriod site for help. The DotStars are not something we make and are used in many other systems and processors.
