New here. Is there an LED strip that bends well?
apalacpac
Post by apalacpac »
I want to make a mask like this, but wondering if the LED strips will bend at the corners well enough?
oesterle
Re: New here. Is there an LED strip that bends well?
Post by oesterle »
Hi, apalacpac!
While you might get a strip to bend like that, it's not a good idea, and can eventually be a point of failure.
I would cut the strip near the bend, and use three short strands of silicone wire to connect each piece of strip to the next.
I love working with the Silicone Cover Stranded-Core Wire - 2m 26AWG Black. (It's also available in various colors, lengths, and gauges.) A similar technique is used in the Gemma Firewalker Lite Sneakers tutorial.
The Adafruit NeoPixel Überguide section on NeoPixel strips has more good info.
While it can be a little tricky at first to cut up and connect cut strips, I encourage you to try it out, and be persistent. I buy more strip than I need, so in case part of project doesn't light up, I can quickly replace it.
Cheers,
Eric
apalacpac
Post by apalacpac »
Thanks oesterle!
Which LED strips do you think those are? 60 LEDS Per meter?
Franklin97355
Post by Franklin97355 »
That looks about right.
oesterle
Post by oesterle »
60 LED/m is about 1.5 LEDs per inch, or about 17mm (0.66 inch) apart, center-to-center.
144 LED/m is about 3.7 LEDs per inch, or 7mm (0.27 inch) apart, center to center.
To get a good idea of the density, before you buy, try punching holes in black paper along a line, in either density. Place a smartphone with a bright colorful gradient behind the perforations.
These look denser than 60/m to me. However, the 60/m are much easier to cut and solder, and are a good choice if this is your first time working with strips.
I'd suggest building in steps, testing as you cut/solder each segment. That way, you can resolder or replace a finicky segment before the next step: reinforcing the solder joints with hot glue. You'll value making the joints durable, as everyone will want to try on this mask and get a picture, and you'll find yourself reusing the mask at future events.
It would be exciting to see pictures here of your progress!
Happy making!
Cheers,
Eric
