how to uninstall PITFT plus software on a RPi 3B+
- xetum
I'm about to install PITFT plus display software with adafruit-pitft.sh script. I'm going to make some tests with console-only and graphics display mirroring and would like to know in advance how to uninstall it completely and revert to HDMI-only setup
- xetum
Re: how to uninstall PITFT plus software on a RPi 3B+
More specifically. If I look at adafruit-pitft.sh script:
and mirror displays, there is no chance to restore HDMI default since uninstall_fbcp isn't invoked. Only way would be to install console on the PiTFT display and then rerun and answer no to both questions. Perhaps a modified script like:
would do the job?
# ask for console access
if ask "Would you like the console to appear on the PiTFT display?"; then
info PITFT "Updating console to PiTFT..."
uninstall_fbcp || bail "Unable to uninstall fbcp"
install_console || bail "Unable to configure console"
else
info PITFT "Making sure console doesn't use PiTFT"
uninstall_console || bail "Unable to configure console"
if ask "Would you like the HDMI display to mirror to the PiTFT display?"; then
info PITFT "Adding FBCP support..."
install_fbcp || bail "Unable to configure fbcp"
if [ -e /etc/lightdm ]; then
info PITFT "Updating X11 default calibration..."
update_xorg || bail "Unable to update calibration"
fi
fi
fi
else
else
# ADD AN ELSE ALTERNATIVE
fi
fi
- CoreyWC1
Been trying to figure out this same thing, Ideally would like the option to switch back and forth between the TV/ monitor and the TFT. Was under the impression that the easy install script did that but it's proving to not be the case
- stangogh
This really should exist.
The script provided in this tutorial does it:
http://www.raspberrypiwiki.com/index.php/2.2_LCD
- adafruit_support_carter
In general, just run the script again and select different options.
