I use this display (HDMI 5" 800x480 Display Backpack - With Resistive Touchscreen PID: 2260) on a project and I recently purchased 5 more displays. It seems that the display is not reporting what it is to the host system, in my case a NUC running Linux.
I have tried all 5 new display's and they all have the same issue. I tested one from the previous batch and they work just fine.
Problem: The NUC is plugged into a large monitor, remove the HDMI cable and plug into the 5" display, The video will not resize.
Example pictures:
Connected to the large monitor
Moved the HDMI cable from large monitor to the 5" / Picture will not resize
Move the HDMI cable to the 5" from a previous purchase that works every time
I noted on the display setting that the 5" display from the previous batch shows "Add -DATA Gmbh 7". On the latest purchase, there is nothing displayed, its blank. Like the firmware to the video driver did not get flashed correctly?
Let me know what else you need to help me resolve this as I am out of monitors and need to purchase more ASAP.
HDMI 5" Display - With Touch - Not resizing
- rdavidson
- rdavidson
Re: HDMI 5" Display - With Touch - Not resizing
Did a little more research and purchased a couple different 5" monitors from Amazon that work . Here is what I found.
Previous batch sample telling the OS what it is so that it can make the proper adjustments and display correctly. New batch, as you can see it's not displaying what it is, and will not resize correctly. 22" large monitor, adjusts correctly and presents itself to the OS. How about a letting me know what to do with the 5 units I have that are not working, and a bigger question, has this been fixed or do I need to redesign my project to accept a different monitor?
- rdavidson
Amazon units that are also working correctly:
Thanks for the help, and I also hope this helps to resolve this issue.
- rdavidson
Its been over a week. Has this problem with the displays been fixed? I need about 20 more "Working: displays... do I need to place an order with someone else?
Thanks for the support...
- adafruit_support_carter
Did you do anything to the first one to change its EDID? Or are you using all of them as delivered?
- rdavidson
All as delivered.
The previous purchase of 13 units work normally. The issue only came up on the current 5 units that I have.
It's acting like your recent ones do not have any EDID info in them. I'll ask and see if any thing might have changed from when you ordered the first batch to this most recent batch. If you want to try setting the EDID, the info here should help:
viewtopic.php?f=47&t=141755
- adafruit2
hiya email support@adafruit for an RMA on those with the RMA code "FORPHIL" and we'll get you 5 new ones!
where/when did you get the 5 that dont work?
- rdavidson
Email sent and thank you.adafruit2 wrote:hiya email support@adafruit for an RMA on those with the RMA code "FORPHIL" and we'll get you 5 new ones!
- rdavidson
The link you provided is for this post ... ;)adafruit_support_carter wrote:It's acting like your recent ones do not have any EDID info in them. I'll ask and see if any thing might have changed from when you ordered the first batch to this most recent batch. If you want to try setting the EDID, the info here should help:
Thanks for the help!
Sorry. Bad copypasta on my part. Here's the link:
https://learn.adafruit.com/adafruit-tfp ... g-the-edid
- rdavidson
The new 5" Displays I received as replacements have the same issue.
No EDID, so the display will not resize.
Has this been fixed?
I have 5 displays with this issue and if there was a simple fix to load the EDID I would try that?
- adafruit2
rd, hmm - did you send back the 5 from before?
- rdavidson
No, I was asked to toss them as they were not usable.adafruit2 wrote:rd, hmm - did you send back the 5 from before?
- adafruit2
hiya - was that support@adafruit that said to toss em? no biggie, but don't want it to happen again :)
