Issue with ST7789
Issue with ST7789
by travbum on Wed Jan 02, 2019 10:21 pm
I've tried following the sample code file graphicstest to connect this to both a Feather Huzzah and Arduino Uno with no luck. All I get is a backlit black screen. The code uploads and I see messages sent back via Serial.
For the Arduino, I connected the pins like so:
Vi -> 5V
3V -> Not Connected
G -> Ground
CL -> Pin 13
SO -> Not Connected
SI -> Pin 11
TC -> Pin 10
RT -> Pin 9
DC -> Pin 8
CC -> Not Connected
BL -> Not Connected
What am I doing wrong? Or do I have a defective product?
travbum
Re: Issue with ST7789
by adafruit_support_bill on Thu Jan 03, 2019 7:10 am
Please post some photos showing your soldering and connections.
by travbum on Thu Jan 03, 2019 10:19 am
travbum
by adafruit_support_bill on Thu Jan 03, 2019 10:31 am
The soldering looks fine. We also need to see where all the wires go to double-check the connections.
by travbum on Thu Jan 03, 2019 10:41 am
If you scroll down the second photo has that.
travbum
by adafruit_support_bill on Thu Jan 03, 2019 11:09 am
What messages do you see printed to the serial monitor when running GraphicsTest?
by travbum on Thu Jan 03, 2019 11:56 am
Hello! ST77xx TFT Test
Initialized
188
done
travbum
by adafruit_support_bill on Thu Jan 03, 2019 12:12 pm
Sounds like it thinks it is talking to the display. Unfortunately the display controller is a 'write-only' device and there is no positive confirmation.
Try re-wiring the data lines with a different bunch of jumpers. We do occasionally see problems caused by a defective jumper.
by travbum on Thu Jan 03, 2019 12:23 pm
adafruit_support_bill wrote:Sounds like it thinks it is talking to the display. Unfortunately the display controller is a 'write-only' device and there is no positive confirmation.
I tried doing this on two different boards, ESP8266 and an Arduino, with two completely different sets of wires, on two different breadboards.
travbum
by adafruit_support_bill on Thu Jan 03, 2019 12:32 pm
OK. Please contact support@adafruit.com with a link to this thread and we can replace the display.
by travbum on Thu Jan 03, 2019 12:45 pm
Thanks for your help!
Bit of a frustration but I learned a lot about those displays.
travbum
by travbum on Mon Jan 07, 2019 8:04 pm
Hi, So I just got my replacement part and I'm having the exact same issue.
Was there a bad batch of boards or something? Are there bugs with the library perhaps?
travbum
by adafruit_support_bill on Tue Jan 08, 2019 7:28 am
Each of these boards is tested in production. We have not had many issues with them.
The graphicstest code by default assumes hardware SPI and the wiring you are using is for an Arduino UNO. Different Arduino boards will have different SPI pins. Make sure that you are using the correct pins for your board. You also might try the software SPI option. See the comments in the code for details.
by guma on Sat Jan 12, 2019 11:21 am
I had exactly the same issue as travbum. The display seems to be initiated correctly but doesn´t show anything than black screen. I found that´s only a problem of library versions 1.2.0 and 1.2.6. For some reasons there ist a mistake in the display init section in the file 'Adafruit_ST77xx.cpp' (both versions 1.2.0 and 1.2.6). The 'startWrite()' and 'endWrite()' commands are outside the while loop instead of inside this structure.
This is the original code (excerpt of Adafruit_ST77xx.cpp) - I have seperated the 'startWrite()' and 'endWrite()' commands for better overview:
void Adafruit_ST77xx::displayInit(const uint8_t *addr) {
  uint8_t  numCommands, numArgs;
  uint16_t ms;
  startWrite();
  numCommands = pgm_read_byte(addr++);   // Number of commands to follow
  while(numCommands--) {                 // For each command...
    writeCommand(pgm_read_byte(addr++)); // Read, issue command
    numArgs  = pgm_read_byte(addr++);    // Number of args to follow
    ms       = numArgs & ST_CMD_DELAY;   // If hibit set, delay follows args
    numArgs &= ~ST_CMD_DELAY;            // Mask out delay bit
    while(numArgs--) {                   // For each argument...
      spiWrite(pgm_read_byte(addr++));   // Read, issue argument
    if(ms) {
      ms = pgm_read_byte(addr++); // Read post-command delay time (ms)
      if(ms == 255) ms = 500;     // If 255, delay for 500 ms
      delay(ms);
  endWrite();
This is the corrected code:
  uint16_t ms;
    startWrite();
    endWrite();
    if(ms) {
      delay(ms);
Please try it with the descripted modification. As already mentioned above you can also perform a test with software SPI (slow but ok for testing) to check, if your display and the wire connections are ok.
guma
by travbum on Sat Jan 12, 2019 12:12 pm
Hi, sorry I forgot to reply. I found another library elsewhere on the internet that works for it.
travbum
