Fadecandy stopped working
by jcfischer on Thu Jan 03, 2019 4:21 pm
I bought a Fadecandy and an 8x8 Neopixel matrix and soldered them up according to the introductory article on learn.adafruit.com - everything worked perfectly.
I then removed the Matrix and want to attach single strips of 50 Neopixels [1]. I soldered the strip in (location 0 as the matrix before) but the LEDs don't light up. Things I checked
- Voltage on +5 / GND on strip: OK
- There's about a 700 Ohm resistance between the GND and data pads on the Fadecandy (not sure if that's normal)
- The fcserver sees the Fadecandy controller and "Identify" works (the LED on the Fadecandy blinks)
- Resoldered the Matrix (to port 7 this time) => Doesn't work either
What more can I test?
thanks
Jens-Christian
[1]: https://www.aliexpress.com/item/50pcs-P ... 4c4dgsQDQz
jcfischer
Re: Fadecandy stopped working
by adafruit_support_carter on Thu Jan 03, 2019 8:45 pm
Post photos of your current setup showing the solder job on the pins.
by jcfischer on Fri Jan 04, 2019 3:16 pm
Thanks, will do that. I have disassembled most of the things, but will try to get it back to its (non working) state tomorrow and make the pictures
cheers
jc
jcfischer
by jcfischer on Fri Jan 04, 2019 5:28 pm
I just read the sticky post - and - sigh - I wired up the data output from the Fadecandy to the DOU port of the LED strip. Sorry for wasting bandwidth.
I'm still wondering why the 8x8 Matrix doesn't work anymore - I will try to rewire everything tomorrow and see if things fall into place.
/jc
jcfischer
by jcfischer on Sat Jan 05, 2019 11:15 am
and that was indeed the problem. Wiring it the correct way made everything work. In sympathy, even the 8x8 Matrix started working again!
/jc
jcfischer
by adafruit_support_carter on Mon Jan 07, 2019 2:17 pm
Awesome, glad you figured it out. Thanks for letting us know.
