Adafruit RA8875 sclk pin
by Tim_wb0wuq on Wed Jan 09, 2019 7:40 pm
I have an Adafruit RA8875 (1590) and the 7.0" TFT screen (2353). I am connecting it to a Teensy 3.2. Following examples from the Adafruit libraries the hardware connections are:
// Library only supports hardware SPI at this time
// Connect SCLK to UNO Digital #13 (Hardware SPI clock)
// Connect MISO to UNO Digital #12 (Hardware SPI MISO)
// Connect MOSI to UNO Digital #11 (Hardware SPI MOSI)
#define RA8875_INT 3
#define RA8875_CS 10
#define RA8875_RESET 9
However the sketch I am going to write uses Pin #13 for a Arduino FreqCount sketch input. Is there anyway to change the SPI clock Pin? I have looked at the Adafruit RA8875 libraries and don't see any place to change the Pin. Anyone out there that can help?
Tim
Tim_wb0wuq
Re: Adafruit RA8875 sclk pin
by adafruit_support_carter on Wed Jan 09, 2019 7:49 pm
It looks like the library is setup to only use hardware SPI:
https://github.com/adafruit/Adafruit_RA ... 8875.h#L68
So you can't change the clock pin.
If you want, file an issue in the repo to allow for software SPI. Maybe there's a reason it wasn't added. But you can at least raise the question there:
https://github.com/adafruit/Adafruit_RA8875/issues
