16x2 lcd display two pins used will not turn on
by Jebb1 on Thu Jan 10, 2019 11:21 pm
apologies in advance as im a complete beginer to this stuff but my recently purchased LCD Shield Kit w/ 16x2 Character Display - Only 2 pins used! (BLUE AND
WHITE) will not turn on or light up when used with example code from the adafruit supplied library, however now errors pop up when uploading code to my metro 328. i have checked all the soldering and cannot fin any visible problem. and advice would be great.
pics of circuit attached below
Jebb1
Re: 16x2 lcd display two pins used will not turn on
by franklin97355 on Fri Jan 11, 2019 12:23 am
Could you post larger pictures so we can see the connections more clearly and tell us what you are connecting it to and what code you are running?
franklin97355
by Jebb1 on Sat Jan 12, 2019 1:52 am
sure, thanks for the quick response. hopefully these images are a bit better.
yellow = slc
black = sda
red = 5v pin
brown = gnd nearest to vin
Jebb1
by Jebb1 on Sat Jan 12, 2019 1:53 am
i am running the example "hello world" from the adafruit lcd shield library
Jebb1
by franklin97355 on Sat Jan 12, 2019 3:11 pm
Take a look at this Soldering Guide and reflow your solder joints then see if that helps.
franklin97355
