Arcade Button Questions
by jimdeprado on Mon Jan 14, 2019 8:29 pm
Hello!
I am building a modular control panel that will be inserted between two fixed panels. I am thinking about using an Pro Micro AT mega32u4 and 6 buttons (p/n 3490) on each side (12 total). I don't think the Micro has enough pins, so I am looking into using a shift register (or two).
    Does this sound reasonable?
    Am I missing something that would prevent me from putting everything together as described above?
    I want to have the buttons light up depending on the game that is chosen. I can create a listing that would say for game X, light buttons 1,2 and 3 and leave 4, 5 and six unlit. It would be easier to have this list resident in a text file, but I can hard code it into the code too.
    Can I change the color of the LEDs or are they just white?
    Can I change the brightness of the LEDs?
Once I get some things ordered, I will post back with my progress and any additional questions.
Thanks in advance,
Jim
jimdeprado
Re: Arcade Button Questions
by adafruit_support_bill on Tue Jan 15, 2019 6:48 am
Might want to consider a GPIO expander chip like the MCP23017: https://www.adafruit.com/product/732
The LEDs on those buttons are single color. We do have RGB buttons - but not in the arcade style: https://www.adafruit.com/product/3423
There is a tutorial here that describes how to retrofit an RGB Neopixel into an arcade-style button: https://learn.adafruit.com/neopixel-arc ... n/overview
This can be done easily with the Neopixel-modified buttons, since they have build-in controllers. For standard LEDs, you would need a PWM channel per LED (3 channels for RGB LEDs). You could do that with one of these boards:
https://www.adafruit.com/product/1455
by jimdeprado on Tue Jan 15, 2019 3:47 pm
Thank you very much for the information. I need to do a bit more research, but this certainly gets me going in the right direction.
Thanks again!
Jim
jimdeprado
by jimdeprado on Sun Jan 20, 2019 1:57 pm
Thanks for the help! It worked perfectly!
Jim
jimdeprado
by adafruit_support_bill on Sun Jan 20, 2019 2:36 pm
Good to hear. Thanks for the update.
