Pi 5 inch backpack touchscreen picture not working
by Nkirby13 on Wed Jan 23, 2019 8:05 pm
I got the touchscreen for Christmas and hooked it up. I even formatted the picture re scaling but its not scaled properly and it looks weird. It keeps looking like it's refreshing over and over and the touchscreen isn't working.
Nkirby13
Re: Pi 5 inch backpack touchscreen picture not working
by Nkirby13 on Fri Jan 25, 2019 8:12 pm
Here is a picture
Nkirby13
by adafruit_support_carter on Mon Jan 28, 2019 2:05 pm
It looks like maybe you just haven't done the config step here:
https://learn.adafruit.com/adafruit-5-8 ... -pi-config
by Nkirby13 on Sat Feb 09, 2019 7:24 pm
I did it but I'll post the script later... Still not working.
Nkirby13
by adafruit_support_carter on Sun Feb 10, 2019 1:55 pm
Weird. The screen is working - it's showing stuff. It just seems like the scaling isn't set right for some reason. That's what the config file linked above *should* take care of.
by Nkirby13 on Thu Feb 21, 2019 1:48 am
Attached is my config file
config.txt
(1.76 KiB) Downloaded 5 times
Nkirby13
by adafruit_support_carter on Thu Feb 21, 2019 1:40 pm
Try commenting out the overclocking - the last line. Change it to:
#arm_freq=800
Also check that you've done this:
use the raspi-config tool to force audio to the 3.5mm jack (not HDMI or auto). Not all screens support audio over HDMI, and in this case it may actualy interfere with the display.
by Nkirby13 on Tue Feb 26, 2019 1:23 am
All sorted! Is there a way to get a keyboard to come up when you touch in a text fill box? Like to sign in
Nkirby13
by adafruit_support_carter on Tue Feb 26, 2019 1:41 am
I've never tried using one, but check out something called "matchbox-keyboard". Seems to be what a lot of people try using.
