custom 2.2 pitft screen
by darkmoon3d on Wed Feb 06, 2019 3:57 pm
I'm prototyping out building custom pcb for 2.2" pitft screen. https://learn.adafruit.com/pigrrl-zero?view=all
Not having luck with current build so wanted to confirm if these are correct components. Have changed resistor size to 1206 to make soldering easier.
Last year there was bad batch of 2.2" screens with wrong component https://forums.adafruit.com/viewtopic.php?f=50&t=132799&p=665628#p665628 so wanted to make sure I was using correct component.
SOIC8_150MIL CAT24C32 https://www.digikey.com/short/j0v5ch
AXP803 SOT23 https://www.digikey.com/short/j0v59c
SWITCH TACTILE SPST-NO 0.05A 12V https://www.digikey.com/short/jnwwfd
NPN Transistror 2N2222 https://www.digikey.com/short/p7dc91
ili9340c TM022HDH26 https://www.ebay.com/itm/1-8-2-2-2-4-in ... 1438.l2649
RESISTOR 1206 - 1k https://www.digikey.com/short/jn1pb4
RESISTOR 1206 - 10k https://www.digikey.com/short/j0109v
RESISTOR 1206 - 100 https://www.digikey.com/short/j010b0
RESISTOR 1206 - 3.9k https://www.digikey.com/short/j010rt
darkmoon3d
Re: custom 2.2 pitft screen
by darkmoon3d on Mon Feb 11, 2019 2:48 pm
Most specifically am unsure if AXP803 and MMBT2222 are correct.
darkmoon3d
