32x32 RGB LED Matrix
by cbh1608 on Fri Feb 08, 2019 5:05 pm
I have tried following almost very guide on the web, but i still can't get my matrix to even turn on a single LED.
If i only connect the power and nothing else, LEDs are flashing like crasy in all colors.
I use the RGB + RTC HAT and Raspberry pi 3 model B rev 1.2
I would love if someone could help me get going in the right direction
cbh1608
Re: 32x32 RGB LED Matrix
by adafruit_support_carter on Fri Feb 08, 2019 5:14 pm
The display needs a data signal to actually show things on the LEDs. Just power is not enough. You'll need to continue hooking it up per the guide:
https://learn.adafruit.com/adafruit-rgb ... i/overview
by cbh1608 on Sat Feb 09, 2019 4:46 am
I did, but it is not working at all, i get no errors from the software and i have triple checked the solderings
cbh1608
by adafruit_support_carter on Sun Feb 10, 2019 2:37 pm
Post a photo of your setup showing how everything is connected.
by cbh1608 on Tue Feb 12, 2019 1:31 pm
I figured out that the HAT doesn’t work and connected the matrix directly to the Pi..
The matrix now works
cbh1608
