64x32 RGB LED Matrix - 5mm pitch not work...
by ogaworks on Sat Feb 09, 2019 9:40 pm
I got 64x32 RGB LED Matrix - 5mm pitch.
スクリーンショット 2019-02-10 10.20.45.png (139.39 KiB) Viewed 154 times
Sometimes it works, sometimes it does not work.
https://youtu.be/63yF3Q-fA8U
Even if I changed the power line or raspberry Pi, it was the same.
It seems that poor contact of power supply part of LED matrix panel?
Please tell me how to do it.
Regards,
Nori
ogaworks
Re: 64x32 RGB LED Matrix - 5mm pitch not work...
by adafruit_support_carter on Fri Feb 15, 2019 10:54 pm
In that video, are you pressing the power connector on the back to create the issue?
It looks like it could be a signal connection issue also. I think I saw a matrix HAT and a ribbon cable there in the video?
by ogaworks on Fri Feb 15, 2019 11:13 pm
Yes. It seems that connection to the panel is lost as soon as the power connector on the back moves a little.
Do I need to upload other videos and photos?
ogaworks
by ogaworks on Fri Feb 15, 2019 11:26 pm
It seems that the power supply is lost when the power connector on the back moves just a little.
ogaworks
by ogaworks on Fri Feb 15, 2019 11:53 pm
@adafruit_support_carter
Please check this.
https://www.youtube.com/watch?v=csK50_zQ0gI
ogaworks
by adafruit_support_carter on Mon Feb 18, 2019 1:10 pm
Thanks for the photos. That all looks OK. Can you post another photo of the solder job on the HAT header pins, and slightly at an angle. I'm a little concerned about the solder on some of them.
Also - if it is related to the power connector, would be willing to try reflowing some more solder on to those pins.
by ogaworks on Fri Mar 29, 2019 1:45 am
I purchased another LED panel.
It was displayed without problems when connecting it with HAT.
So it was not a problem with HAT.
ogaworks
by adafruit_support_carter on Fri Mar 29, 2019 11:52 am
Thanks for the update. This might be fixable. Would you be willing to try adding some solder to those pins on the power conenctor. See if that helps at all.
