10.1 Display problem
by mediart2 on Tue Feb 12, 2019 10:08 pm
Purchased a 10.1" 1280x800 display, order no 1954369. It worked for about 10 minutes then had a problem on the left side of the screen, see photos attached. Using a 12 volt power supply purchased from Addafruit with the display, feeding it with a BrightSign media player via HDMI. Would like to exchange the display for a new one.
Peter Kirby
mediart2
Re: 10.1 Display problem
by franklin97355 on Tue Feb 12, 2019 10:15 pm
Can you post pictures of the connections between the board and the display?
franklin97355
by mediart2 on Wed Feb 13, 2019 5:00 pm
Here are pictures of the board and of the display.
mediart2
by mediart2 on Fri Feb 15, 2019 1:11 pm
Any progress on this problem? Reset all the connectors and no change. Running a white screen from the media player so you can see the problem.
mediart2
by franklin97355 on Fri Feb 15, 2019 2:19 pm
Have you tried any other input source?
franklin97355
by mediart2 on Fri Feb 15, 2019 3:44 pm
Composite in shows the same lines on the right. THink it is a bad screen.
mediart2
by mediart2 on Fri Feb 15, 2019 3:51 pm
Here is a picture of the screen
mediart2
by franklin97355 on Sat Feb 16, 2019 2:50 pm
OK, Please contact support@adafruit.com with a link to this topic and they will get you a replacement.
franklin97355
