neopixel won't turn off
by schlaepfer on Thu Feb 14, 2019 10:22 am
I am working on a project involving 5 neopixel fading in and out one after the other. The whole thing is powered by a Teensy 3.2.
The code is the following:
#define DATA_PIN 7
#define NLEDS 5
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NLEDS, DATA_PIN, NEO_RGBW + NEO_KHZ800);
#define STEP 1000
#define WAIT 1
#define INTER1 50
#define INTER2 20
#define MAX 250
int val1 = 0;
int val2 = 0;
int val3 = 0;
int val4 = 0;
int val5 = 0;
  strip.begin();
  strip.show();
  for (int i=0;i< STEP;i++) {
    val5 = map(i,0, STEP,0,INTER1);
    strip.setPixelColor(4, 0, 0, 0, val5);
    strip.show();
    delay(WAIT);
  delay(WAIT*5);
    val4 = map(i,0, STEP,0,INTER1);
    strip.setPixelColor(3, 0, 0, 0, val4);
    strip.show();
    delay(WAIT);
  delay(WAIT*5);
    val3 = map(i,0, STEP,0,INTER1);
    strip.setPixelColor(2, 0, 0, 0, val3);
    val5 = map(i,0, STEP,INTER1,INTER2);
    strip.show();
    delay(WAIT);
    val2 = map(i,0, STEP,0,INTER1);
    strip.setPixelColor(1, 0, 0, 0, val2);
    val4 = map(i,0, STEP,INTER1,INTER2);
    strip.show();
    delay(WAIT);
    val1 = map(i,0, STEP,0,INTER1);
    strip.setPixelColor(0, 0, 0, 0, val1);
    val3 = map(i,0, STEP,INTER1,INTER2);
    val5 = map(i,0, STEP,INTER2,MAX);
    strip.show();
    delay(WAIT);
    val2 = map(i,0, STEP,INTER1,INTER2);
    val4 = map(i,0, STEP,INTER2,MAX);
    val5 = map(i,0, STEP,MAX,INTER2);
    strip.show();
    delay(WAIT);
    val1 = map(i,0, STEP,INTER1,INTER2);
    val3 = map(i,0, STEP,INTER2,MAX);
    val4 = map(i,0, STEP,MAX,INTER2);
    strip.show();
    delay(WAIT);
    val2 = map(i,0, STEP,INTER2,MAX);
    val3 = map(i,0, STEP,MAX,INTER2);
    val5 = map(i,0, STEP,INTER2,INTER1);
    strip.show();
    delay(WAIT);
    val1 = map(i,0, STEP,INTER2,MAX);
    val2 = map(i,0, STEP,MAX,INTER2);
    val4 = map(i,0, STEP,INTER2,INTER1);
    strip.show();
    delay(WAIT);
    val1 = map(i,0, STEP,MAX,INTER2);
    val3 = map(i,0, STEP,INTER2,INTER1);
    val5 = map(i,0, STEP,INTER1,0);
    strip.show();
    delay(WAIT);
    val2 = map(i,0, STEP,INTER2,INTER1);
    val4 = map(i,0, STEP,INTER1,0);
    strip.show();
    delay(WAIT);
    val1 = map(i,0, STEP,INTER2,INTER1);
    val3 = map(i,0, STEP,INTER1,0);
    strip.show();
    delay(WAIT);
    val2 = map(i,0, STEP,INTER1,0);
    strip.show();
    delay(WAIT);
    val1 = map(i,0, STEP,INTER1,0);
    strip.show();
    delay(WAIT);
  delay(2000);
Everything works fine, except for one thing (of course): at the end of the loop, the leds never turn off completely. They are always emitting a little light, as if it was set on something between 1 and 5, I'd say.
I tried to change the value of STEP to 100, but it doesn't change much.
The Neopixel are 5 from a RGBW 60LED strip (ID 2842), and the Teensy is running at 72MHz (I also tried at 48MHz, but it doesn't affect the result).
Do you have any idea where it could come from?
schlaepfer
Re: neopixel won't turn off
by adafruit_support_bill on Thu Feb 14, 2019 10:32 am
Your loop goes from zero to step-1
Since i is never equal to STEP, your map will never return zero:
Try:
for (int i=0;i<= STEP;i++)
by schlaepfer on Thu Feb 14, 2019 10:56 am
Oh, it seems obvious now, but in this case, my "for" will loop through 1001 steps, right? Thanks for pointing this out.
However, it doesn't solve my problem either. I put a little Serial.println on my last "for" loop, returning the "val1" value. And it turns out it goes all the way down from 50 (INTER1) to 2 (each value is sent 20 or 21 times, which makes the count to 1001). I don't understand why it doesn't do the last two steps :-s
schlaepfer
by adafruit_support_bill on Thu Feb 14, 2019 12:41 pm
Can you post the last few steps of the serial output - showing the values of both 'i' and 'val1'?
by schlaepfer on Thu Feb 14, 2019 12:59 pm
Of course, here it is, for the last two "for" loops. The output shows "i - val" (respectively val2 and val1)
START
0 - 50
1 - 50
2 - 50
3 - 50
4 - 50
5 - 50
6 - 50
7 - 50
8 - 50
9 - 50
10 - 50
11 - 50
12 - 50
13 - 50
14 - 50
15 - 50
16 - 50
17 - 50
18 - 50
19 - 50
20 - 50
21 - 49
22 - 49
23 - 49
24 - 49
25 - 49
26 - 49
27 - 49
28 - 49
29 - 49
30 - 49
31 - 49
32 - 49
33 - 49
34 - 49
35 - 49
36 - 49
37 - 49
38 - 49
39 - 49
40 - 49
41 - 48
42 - 48
43 - 48
44 - 48
45 - 48
46 - 48
47 - 48
48 - 48
49 - 48
50 - 48
51 - 48
52 - 48
53 - 48
54 - 48
55 - 48
56 - 48
57 - 48
58 - 48
59 - 48
60 - 48
61 - 48
62 - 47
63 - 47
64 - 47
65 - 47
66 - 47
67 - 47
68 - 47
69 - 47
70 - 47
71 - 47
72 - 47
73 - 47
74 - 47
75 - 47
76 - 47
77 - 47
78 - 47
79 - 47
80 - 47
81 - 47
82 - 46
83 - 46
84 - 46
85 - 46
86 - 46
87 - 46
88 - 46
89 - 46
90 - 46
91 - 46
92 - 46
93 - 46
94 - 46
95 - 46
96 - 46
97 - 46
98 - 46
99 - 46
100 - 46
101 - 46
102 - 46
103 - 45
104 - 45
105 - 45
106 - 45
107 - 45
108 - 45
109 - 45
110 - 45
111 - 45
112 - 45
113 - 45
114 - 45
115 - 45
116 - 45
117 - 45
118 - 45
119 - 45
120 - 45
121 - 45
122 - 45
123 - 44
124 - 44
125 - 44
126 - 44
127 - 44
128 - 44
129 - 44
130 - 44
131 - 44
132 - 44
133 - 44
134 - 44
135 - 44
136 - 44
137 - 44
138 - 44
139 - 44
140 - 44
141 - 44
142 - 44
143 - 43
144 - 43
145 - 43
146 - 43
147 - 43
148 - 43
149 - 43
150 - 43
151 - 43
152 - 43
153 - 43
154 - 43
155 - 43
156 - 43
157 - 43
158 - 43
159 - 43
160 - 43
161 - 43
162 - 43
163 - 43
164 - 42
165 - 42
166 - 42
167 - 42
168 - 42
169 - 42
170 - 42
171 - 42
172 - 42
173 - 42
174 - 42
175 - 42
176 - 42
177 - 42
178 - 42
179 - 42
180 - 42
181 - 42
182 - 42
183 - 42
184 - 41
185 - 41
186 - 41
187 - 41
188 - 41
189 - 41
190 - 41
191 - 41
192 - 41
193 - 41
194 - 41
195 - 41
196 - 41
197 - 41
198 - 41
199 - 41
200 - 41
201 - 41
202 - 41
203 - 41
204 - 41
205 - 40
206 - 40
207 - 40
208 - 40
209 - 40
210 - 40
211 - 40
212 - 40
213 - 40
214 - 40
215 - 40
216 - 40
217 - 40
218 - 40
219 - 40
220 - 40
221 - 40
222 - 40
223 - 40
224 - 40
225 - 39
226 - 39
227 - 39
228 - 39
229 - 39
230 - 39
231 - 39
232 - 39
233 - 39
234 - 39
235 - 39
236 - 39
237 - 39
238 - 39
239 - 39
240 - 39
241 - 39
242 - 39
243 - 39
244 - 39
245 - 39
246 - 38
247 - 38
248 - 38
249 - 38
250 - 38
251 - 38
252 - 38
253 - 38
254 - 38
255 - 38
256 - 38
257 - 38
258 - 38
259 - 38
260 - 38
261 - 38
262 - 38
263 - 38
264 - 38
265 - 38
266 - 37
267 - 37
268 - 37
269 - 37
270 - 37
271 - 37
272 - 37
273 - 37
274 - 37
275 - 37
276 - 37
277 - 37
278 - 37
279 - 37
280 - 37
281 - 37
282 - 37
283 - 37
284 - 37
285 - 37
286 - 36
287 - 36
288 - 36
289 - 36
290 - 36
291 - 36
292 - 36
293 - 36
294 - 36
295 - 36
296 - 36
297 - 36
298 - 36
299 - 36
300 - 36
301 - 36
302 - 36
303 - 36
304 - 36
305 - 36
306 - 36
307 - 35
308 - 35
309 - 35
310 - 35
311 - 35
312 - 35
313 - 35
314 - 35
315 - 35
316 - 35
317 - 35
318 - 35
319 - 35
320 - 35
321 - 35
322 - 35
323 - 35
324 - 35
325 - 35
326 - 35
327 - 34
328 - 34
329 - 34
330 - 34
331 - 34
332 - 34
333 - 34
334 - 34
335 - 34
336 - 34
337 - 34
338 - 34
339 - 34
340 - 34
341 - 34
342 - 34
343 - 34
344 - 34
345 - 34
346 - 34
347 - 34
348 - 33
349 - 33
350 - 33
351 - 33
352 - 33
353 - 33
354 - 33
355 - 33
356 - 33
357 - 33
358 - 33
359 - 33
360 - 33
361 - 33
362 - 33
363 - 33
364 - 33
365 - 33
366 - 33
367 - 33
368 - 32
369 - 32
370 - 32
371 - 32
372 - 32
373 - 32
374 - 32
375 - 32
376 - 32
377 - 32
378 - 32
379 - 32
380 - 32
381 - 32
382 - 32
383 - 32
384 - 32
385 - 32
386 - 32
387 - 32
388 - 32
389 - 31
390 - 31
391 - 31
392 - 31
393 - 31
394 - 31
395 - 31
396 - 31
397 - 31
398 - 31
399 - 31
400 - 31
401 - 31
402 - 31
403 - 31
404 - 31
405 - 31
406 - 31
407 - 31
408 - 31
409 - 30
410 - 30
411 - 30
412 - 30
413 - 30
414 - 30
415 - 30
416 - 30
417 - 30
418 - 30
419 - 30
420 - 30
421 - 30
422 - 30
423 - 30
424 - 30
425 - 30
426 - 30
427 - 30
428 - 30
429 - 29
430 - 29
431 - 29
432 - 29
433 - 29
434 - 29
435 - 29
436 - 29
437 - 29
438 - 29
439 - 29
440 - 29
441 - 29
442 - 29
443 - 29
444 - 29
445 - 29
446 - 29
447 - 29
448 - 29
449 - 29
450 - 28
451 - 28
452 - 28
453 - 28
454 - 28
455 - 28
456 - 28
457 - 28
458 - 28
459 - 28
460 - 28
461 - 28
462 - 28
463 - 28
464 - 28
465 - 28
466 - 28
467 - 28
468 - 28
469 - 28
470 - 27
471 - 27
472 - 27
473 - 27
474 - 27
475 - 27
476 - 27
477 - 27
478 - 27
479 - 27
480 - 27
481 - 27
482 - 27
483 - 27
484 - 27
485 - 27
486 - 27
487 - 27
488 - 27
489 - 27
490 - 27
491 - 26
492 - 26
493 - 26
494 - 26
495 - 26
496 - 26
497 - 26
498 - 26
499 - 26
500 - 26
501 - 26
502 - 26
503 - 26
504 - 26
505 - 26
506 - 26
507 - 26
508 - 26
509 - 26
510 - 26
511 - 25
512 - 25
513 - 25
514 - 25
515 - 25
516 - 25
517 - 25
518 - 25
519 - 25
520 - 25
521 - 25
522 - 25
523 - 25
524 - 25
525 - 25
526 - 25
527 - 25
528 - 25
529 - 25
530 - 25
531 - 25
532 - 24
533 - 24
534 - 24
535 - 24
536 - 24
537 - 24
538 - 24
539 - 24
540 - 24
541 - 24
542 - 24
543 - 24
544 - 24
545 - 24
546 - 24
547 - 24
548 - 24
549 - 24
550 - 24
551 - 24
552 - 23
553 - 23
554 - 23
555 - 23
556 - 23
557 - 23
558 - 23
559 - 23
560 - 23
561 - 23
562 - 23
563 - 23
564 - 23
565 - 23
566 - 23
567 - 23
568 - 23
569 - 23
570 - 23
571 - 23
572 - 22
573 - 22
574 - 22
575 - 22
576 - 22
577 - 22
578 - 22
579 - 22
580 - 22
581 - 22
582 - 22
583 - 22
584 - 22
585 - 22
586 - 22
587 - 22
588 - 22
589 - 22
590 - 22
591 - 22
592 - 22
593 - 21
594 - 21
595 - 21
596 - 21
597 - 21
598 - 21
599 - 21
600 - 21
601 - 21
602 - 21
603 - 21
604 - 21
605 - 21
606 - 21
607 - 21
608 - 21
609 - 21
610 - 21
611 - 21
612 - 21
613 - 20
614 - 20
615 - 20
616 - 20
617 - 20
618 - 20
619 - 20
620 - 20
621 - 20
622 - 20
623 - 20
624 - 20
625 - 20
626 - 20
627 - 20
628 - 20
629 - 20
630 - 20
631 - 20
632 - 20
633 - 20
634 - 19
635 - 19
636 - 19
637 - 19
638 - 19
639 - 19
640 - 19
641 - 19
642 - 19
643 - 19
644 - 19
645 - 19
646 - 19
647 - 19
648 - 19
649 - 19
650 - 19
651 - 19
652 - 19
653 - 19
654 - 18
655 - 18
656 - 18
657 - 18
658 - 18
659 - 18
660 - 18
661 - 18
662 - 18
663 - 18
664 - 18
665 - 18
666 - 18
667 - 18
668 - 18
669 - 18
670 - 18
671 - 18
672 - 18
673 - 18
674 - 18
675 - 17
676 - 17
677 - 17
678 - 17
679 - 17
680 - 17
681 - 17
682 - 17
683 - 17
684 - 17
685 - 17
686 - 17
687 - 17
688 - 17
689 - 17
690 - 17
691 - 17
692 - 17
693 - 17
694 - 17
695 - 16
696 - 16
697 - 16
698 - 16
699 - 16
700 - 16
701 - 16
702 - 16
703 - 16
704 - 16
705 - 16
706 - 16
707 - 16
708 - 16
709 - 16
710 - 16
711 - 16
712 - 16
713 - 16
714 - 16
715 - 15
716 - 15
717 - 15
718 - 15
719 - 15
720 - 15
721 - 15
722 - 15
723 - 15
724 - 15
725 - 15
726 - 15
727 - 15
728 - 15
729 - 15
730 - 15
731 - 15
732 - 15
733 - 15
734 - 15
735 - 15
736 - 14
737 - 14
738 - 14
739 - 14
740 - 14
741 - 14
742 - 14
743 - 14
744 - 14
745 - 14
746 - 14
747 - 14
748 - 14
749 - 14
750 - 14
751 - 14
752 - 14
753 - 14
754 - 14
755 - 14
756 - 13
757 - 13
758 - 13
759 - 13
760 - 13
761 - 13
762 - 13
763 - 13
764 - 13
765 - 13
766 - 13
767 - 13
768 - 13
769 - 13
770 - 13
771 - 13
772 - 13
773 - 13
774 - 13
775 - 13
776 - 13
777 - 12
778 - 12
779 - 12
780 - 12
781 - 12
782 - 12
783 - 12
784 - 12
785 - 12
786 - 12
787 - 12
788 - 12
789 - 12
790 - 12
791 - 12
792 - 12
793 - 12
794 - 12
795 - 12
796 - 12
797 - 11
798 - 11
799 - 11
800 - 11
801 - 11
802 - 11
803 - 11
804 - 11
805 - 11
806 - 11
807 - 11
808 - 11
809 - 11
810 - 11
811 - 11
812 - 11
813 - 11
814 - 11
815 - 11
816 - 11
817 - 11
818 - 10
819 - 10
820 - 10
821 - 10
822 - 10
823 - 10
824 - 10
825 - 10
826 - 10
827 - 10
828 - 10
829 - 10
830 - 10
831 - 10
832 - 10
833 - 10
834 - 10
835 - 10
836 - 10
837 - 10
838 - 9
839 - 9
840 - 9
841 - 9
842 - 9
843 - 9
844 - 9
845 - 9
846 - 9
847 - 9
848 - 9
849 - 9
850 - 9
851 - 9
852 - 9
853 - 9
854 - 9
855 - 9
856 - 9
857 - 9
858 - 8
859 - 8
860 - 8
861 - 8
862 - 8
863 - 8
864 - 8
865 - 8
866 - 8
867 - 8
868 - 8
869 - 8
870 - 8
871 - 8
872 - 8
873 - 8
874 - 8
875 - 8
876 - 8
877 - 8
878 - 8
879 - 7
880 - 7
881 - 7
882 - 7
883 - 7
884 - 7
885 - 7
886 - 7
887 - 7
888 - 7
889 - 7
890 - 7
891 - 7
892 - 7
893 - 7
894 - 7
895 - 7
896 - 7
897 - 7
898 - 7
899 - 6
900 - 6
901 - 6
902 - 6
903 - 6
904 - 6
905 - 6
906 - 6
907 - 6
908 - 6
909 - 6
910 - 6
911 - 6
912 - 6
913 - 6
914 - 6
915 - 6
916 - 6
917 - 6
918 - 6
919 - 6
920 - 5
921 - 5
922 - 5
923 - 5
924 - 5
925 - 5
926 - 5
927 - 5
928 - 5
929 - 5
930 - 5
931 - 5
932 - 5
933 - 5
934 - 5
935 - 5
936 - 5
937 - 5
938 - 5
939 - 5
940 - 4
941 - 4
942 - 4
943 - 4
944 - 4
945 - 4
946 - 4
947 - 4
948 - 4
949 - 4
950 - 4
951 - 4
952 - 4
953 - 4
954 - 4
955 - 4
956 - 4
957 - 4
958 - 4
959 - 4
960 - 4
961 - 3
962 - 3
963 - 3
964 - 3
965 - 3
966 - 3
967 - 3
968 - 3
969 - 3
970 - 3
971 - 3
972 - 3
973 - 3
974 - 3
975 - 3
976 - 3
977 - 3
978 - 3
979 - 3
980 - 3
981 - 2
982 - 2
983 - 2
984 - 2
985 - 2
986 - 2
987 - 2
988 - 2
989 - 2
990 - 2
991 - 2
992 - 2
993 - 2
994 - 2
995 - 2
996 - 2
997 - 2
998 - 2
999 - 2
1000 - 2
0 - 50
1 - 50
2 - 50
3 - 50
4 - 50
5 - 50
6 - 50
7 - 50
8 - 50
9 - 50
10 - 50
11 - 50
12 - 50
13 - 50
14 - 50
15 - 50
16 - 50
17 - 50
18 - 50
19 - 50
20 - 50
21 - 49
22 - 49
23 - 49
24 - 49
25 - 49
26 - 49
27 - 49
28 - 49
29 - 49
30 - 49
31 - 49
32 - 49
33 - 49
34 - 49
35 - 49
36 - 49
37 - 49
38 - 49
39 - 49
40 - 49
41 - 48
42 - 48
43 - 48
44 - 48
45 - 48
46 - 48
47 - 48
48 - 48
49 - 48
50 - 48
51 - 48
52 - 48
53 - 48
54 - 48
55 - 48
56 - 48
57 - 48
58 - 48
59 - 48
60 - 48
61 - 48
62 - 47
63 - 47
64 - 47
65 - 47
66 - 47
67 - 47
68 - 47
69 - 47
70 - 47
71 - 47
72 - 47
73 - 47
74 - 47
75 - 47
76 - 47
77 - 47
78 - 47
79 - 47
80 - 47
81 - 47
82 - 46
83 - 46
84 - 46
85 - 46
86 - 46
87 - 46
88 - 46
89 - 46
90 - 46
91 - 46
92 - 46
93 - 46
94 - 46
95 - 46
96 - 46
97 - 46
98 - 46
99 - 46
100 - 46
101 - 46
102 - 46
103 - 45
104 - 45
105 - 45
106 - 45
107 - 45
108 - 45
109 - 45
110 - 45
111 - 45
112 - 45
113 - 45
114 - 45
115 - 45
116 - 45
117 - 45
118 - 45
119 - 45
120 - 45
121 - 45
122 - 45
123 - 44
124 - 44
125 - 44
126 - 44
127 - 44
128 - 44
129 - 44
130 - 44
131 - 44
132 - 44
133 - 44
134 - 44
135 - 44
136 - 44
137 - 44
138 - 44
139 - 44
140 - 44
141 - 44
142 - 44
143 - 43
144 - 43
145 - 43
146 - 43
147 - 43
148 - 43
149 - 43
150 - 43
151 - 43
152 - 43
153 - 43
154 - 43
155 - 43
156 - 43
157 - 43
158 - 43
159 - 43
160 - 43
161 - 43
162 - 43
163 - 43
164 - 42
165 - 42
166 - 42
167 - 42
168 - 42
169 - 42
170 - 42
171 - 42
172 - 42
173 - 42
174 - 42
175 - 42
176 - 42
177 - 42
178 - 42
179 - 42
180 - 42
181 - 42
182 - 42
183 - 42
184 - 41
185 - 41
186 - 41
187 - 41
188 - 41
189 - 41
190 - 41
191 - 41
192 - 41
193 - 41
194 - 41
195 - 41
196 - 41
197 - 41
198 - 41
199 - 41
200 - 41
201 - 41
202 - 41
203 - 41
204 - 41
205 - 40
206 - 40
207 - 40
208 - 40
209 - 40
210 - 40
211 - 40
212 - 40
213 - 40
214 - 40
215 - 40
216 - 40
217 - 40
218 - 40
219 - 40
220 - 40
221 - 40
222 - 40
223 - 40
224 - 40
225 - 39
226 - 39
227 - 39
228 - 39
229 - 39
230 - 39
231 - 39
232 - 39
233 - 39
234 - 39
235 - 39
236 - 39
237 - 39
238 - 39
239 - 39
240 - 39
241 - 39
242 - 39
243 - 39
244 - 39
245 - 39
246 - 38
247 - 38
248 - 38
249 - 38
250 - 38
251 - 38
252 - 38
253 - 38
254 - 38
255 - 38
256 - 38
257 - 38
258 - 38
259 - 38
260 - 38
261 - 38
262 - 38
263 - 38
264 - 38
265 - 38
266 - 37
267 - 37
268 - 37
269 - 37
270 - 37
271 - 37
272 - 37
273 - 37
274 - 37
275 - 37
276 - 37
277 - 37
278 - 37
279 - 37
280 - 37
281 - 37
282 - 37
283 - 37
284 - 37
285 - 37
286 - 36
287 - 36
288 - 36
289 - 36
290 - 36
291 - 36
292 - 36
293 - 36
294 - 36
295 - 36
296 - 36
297 - 36
298 - 36
299 - 36
300 - 36
301 - 36
302 - 36
303 - 36
304 - 36
305 - 36
306 - 36
307 - 35
308 - 35
309 - 35
310 - 35
311 - 35
312 - 35
313 - 35
314 - 35
315 - 35
316 - 35
317 - 35
318 - 35
319 - 35
320 - 35
321 - 35
322 - 35
323 - 35
324 - 35
325 - 35
326 - 35
327 - 34
328 - 34
329 - 34
330 - 34
331 - 34
332 - 34
333 - 34
334 - 34
335 - 34
336 - 34
337 - 34
338 - 34
339 - 34
340 - 34
341 - 34
342 - 34
343 - 34
344 - 34
345 - 34
346 - 34
347 - 34
348 - 33
349 - 33
350 - 33
351 - 33
352 - 33
353 - 33
354 - 33
355 - 33
356 - 33
357 - 33
358 - 33
359 - 33
360 - 33
361 - 33
362 - 33
363 - 33
364 - 33
365 - 33
366 - 33
367 - 33
368 - 32
369 - 32
370 - 32
371 - 32
372 - 32
373 - 32
374 - 32
375 - 32
376 - 32
377 - 32
378 - 32
379 - 32
380 - 32
381 - 32
382 - 32
383 - 32
384 - 32
385 - 32
386 - 32
387 - 32
388 - 32
389 - 31
390 - 31
391 - 31
392 - 31
393 - 31
394 - 31
395 - 31
396 - 31
397 - 31
398 - 31
399 - 31
400 - 31
401 - 31
402 - 31
403 - 31
404 - 31
405 - 31
406 - 31
407 - 31
408 - 31
409 - 30
410 - 30
411 - 30
412 - 30
413 - 30
414 - 30
415 - 30
416 - 30
417 - 30
418 - 30
419 - 30
420 - 30
421 - 30
422 - 30
423 - 30
424 - 30
425 - 30
426 - 30
427 - 30
428 - 30
429 - 29
430 - 29
431 - 29
432 - 29
433 - 29
434 - 29
435 - 29
436 - 29
437 - 29
438 - 29
439 - 29
440 - 29
441 - 29
442 - 29
443 - 29
444 - 29
445 - 29
446 - 29
447 - 29
448 - 29
449 - 29
450 - 28
451 - 28
452 - 28
453 - 28
454 - 28
455 - 28
456 - 28
457 - 28
458 - 28
459 - 28
460 - 28
461 - 28
462 - 28
463 - 28
464 - 28
465 - 28
466 - 28
467 - 28
468 - 28
469 - 28
470 - 27
471 - 27
472 - 27
473 - 27
474 - 27
475 - 27
476 - 27
477 - 27
478 - 27
479 - 27
480 - 27
481 - 27
482 - 27
483 - 27
484 - 27
485 - 27
486 - 27
487 - 27
488 - 27
489 - 27
490 - 27
491 - 26
492 - 26
493 - 26
494 - 26
495 - 26
496 - 26
497 - 26
498 - 26
499 - 26
500 - 26
501 - 26
502 - 26
503 - 26
504 - 26
505 - 26
506 - 26
507 - 26
508 - 26
509 - 26
510 - 26
511 - 25
512 - 25
513 - 25
514 - 25
515 - 25
516 - 25
517 - 25
518 - 25
519 - 25
520 - 25
521 - 25
522 - 25
523 - 25
524 - 25
525 - 25
526 - 25
527 - 25
528 - 25
529 - 25
530 - 25
531 - 25
532 - 24
533 - 24
534 - 24
535 - 24
536 - 24
537 - 24
538 - 24
539 - 24
540 - 24
541 - 24
542 - 24
543 - 24
544 - 24
545 - 24
546 - 24
547 - 24
548 - 24
549 - 24
550 - 24
551 - 24
552 - 23
553 - 23
554 - 23
555 - 23
556 - 23
557 - 23
558 - 23
559 - 23
560 - 23
561 - 23
562 - 23
563 - 23
564 - 23
565 - 23
566 - 23
567 - 23
568 - 23
569 - 23
570 - 23
571 - 23
572 - 22
573 - 22
574 - 22
575 - 22
576 - 22
577 - 22
578 - 22
579 - 22
580 - 22
581 - 22
582 - 22
583 - 22
584 - 22
585 - 22
586 - 22
587 - 22
588 - 22
589 - 22
590 - 22
591 - 22
592 - 22
593 - 21
594 - 21
595 - 21
596 - 21
597 - 21
598 - 21
599 - 21
600 - 21
601 - 21
602 - 21
603 - 21
604 - 21
605 - 21
606 - 21
607 - 21
608 - 21
609 - 21
610 - 21
611 - 21
612 - 21
613 - 20
614 - 20
615 - 20
616 - 20
617 - 20
618 - 20
619 - 20
620 - 20
621 - 20
622 - 20
623 - 20
624 - 20
625 - 20
626 - 20
627 - 20
628 - 20
629 - 20
630 - 20
631 - 20
632 - 20
633 - 20
634 - 19
635 - 19
636 - 19
637 - 19
638 - 19
639 - 19
640 - 19
641 - 19
642 - 19
643 - 19
644 - 19
645 - 19
646 - 19
647 - 19
648 - 19
649 - 19
650 - 19
651 - 19
652 - 19
653 - 19
654 - 18
655 - 18
656 - 18
657 - 18
658 - 18
659 - 18
660 - 18
661 - 18
662 - 18
663 - 18
664 - 18
665 - 18
666 - 18
667 - 18
668 - 18
669 - 18
670 - 18
671 - 18
672 - 18
673 - 18
674 - 18
675 - 17
676 - 17
677 - 17
678 - 17
679 - 17
680 - 17
681 - 17
682 - 17
683 - 17
684 - 17
685 - 17
686 - 17
687 - 17
688 - 17
689 - 17
690 - 17
691 - 17
692 - 17
693 - 17
694 - 17
695 - 16
696 - 16
697 - 16
698 - 16
699 - 16
700 - 16
701 - 16
702 - 16
703 - 16
704 - 16
705 - 16
706 - 16
707 - 16
708 - 16
709 - 16
710 - 16
711 - 16
712 - 16
713 - 16
714 - 16
715 - 15
716 - 15
717 - 15
718 - 15
719 - 15
720 - 15
721 - 15
722 - 15
723 - 15
724 - 15
725 - 15
726 - 15
727 - 15
728 - 15
729 - 15
730 - 15
731 - 15
732 - 15
733 - 15
734 - 15
735 - 15
736 - 14
737 - 14
738 - 14
739 - 14
740 - 14
741 - 14
742 - 14
743 - 14
744 - 14
745 - 14
746 - 14
747 - 14
748 - 14
749 - 14
750 - 14
751 - 14
752 - 14
753 - 14
754 - 14
755 - 14
756 - 13
757 - 13
758 - 13
759 - 13
760 - 13
761 - 13
762 - 13
763 - 13
764 - 13
765 - 13
766 - 13
767 - 13
768 - 13
769 - 13
770 - 13
771 - 13
772 - 13
773 - 13
774 - 13
775 - 13
776 - 13
777 - 12
778 - 12
779 - 12
780 - 12
781 - 12
782 - 12
783 - 12
784 - 12
785 - 12
786 - 12
787 - 12
788 - 12
789 - 12
790 - 12
791 - 12
792 - 12
793 - 12
794 - 12
795 - 12
796 - 12
797 - 11
798 - 11
799 - 11
800 - 11
801 - 11
802 - 11
803 - 11
804 - 11
805 - 11
806 - 11
807 - 11
808 - 11
809 - 11
810 - 11
811 - 11
812 - 11
813 - 11
814 - 11
815 - 11
816 - 11
817 - 11
818 - 10
819 - 10
820 - 10
821 - 10
822 - 10
823 - 10
824 - 10
825 - 10
826 - 10
827 - 10
828 - 10
829 - 10
830 - 10
831 - 10
832 - 10
833 - 10
834 - 10
835 - 10
836 - 10
837 - 10
838 - 9
839 - 9
840 - 9
841 - 9
842 - 9
843 - 9
844 - 9
845 - 9
846 - 9
847 - 9
848 - 9
849 - 9
850 - 9
851 - 9
852 - 9
853 - 9
854 - 9
855 - 9
856 - 9
857 - 9
858 - 8
859 - 8
860 - 8
861 - 8
862 - 8
863 - 8
864 - 8
865 - 8
866 - 8
867 - 8
868 - 8
869 - 8
870 - 8
871 - 8
872 - 8
873 - 8
874 - 8
875 - 8
876 - 8
877 - 8
878 - 8
879 - 7
880 - 7
881 - 7
882 - 7
883 - 7
884 - 7
885 - 7
886 - 7
887 - 7
888 - 7
889 - 7
890 - 7
891 - 7
892 - 7
893 - 7
894 - 7
895 - 7
896 - 7
897 - 7
898 - 7
899 - 6
900 - 6
901 - 6
902 - 6
903 - 6
904 - 6
905 - 6
906 - 6
907 - 6
908 - 6
909 - 6
910 - 6
911 - 6
912 - 6
913 - 6
914 - 6
915 - 6
916 - 6
917 - 6
918 - 6
919 - 6
920 - 5
921 - 5
922 - 5
923 - 5
924 - 5
925 - 5
926 - 5
927 - 5
928 - 5
929 - 5
930 - 5
931 - 5
932 - 5
933 - 5
934 - 5
935 - 5
936 - 5
937 - 5
938 - 5
939 - 5
940 - 4
941 - 4
942 - 4
943 - 4
944 - 4
945 - 4
946 - 4
947 - 4
948 - 4
949 - 4
950 - 4
951 - 4
952 - 4
953 - 4
954 - 4
955 - 4
956 - 4
957 - 4
958 - 4
959 - 4
960 - 4
961 - 3
962 - 3
963 - 3
964 - 3
965 - 3
966 - 3
967 - 3
968 - 3
969 - 3
970 - 3
971 - 3
972 - 3
973 - 3
974 - 3
975 - 3
976 - 3
977 - 3
978 - 3
979 - 3
980 - 3
981 - 2
982 - 2
983 - 2
984 - 2
985 - 2
986 - 2
987 - 2
988 - 2
989 - 2
990 - 2
991 - 2
992 - 2
993 - 2
994 - 2
995 - 2
996 - 2
997 - 2
998 - 2
999 - 2
1000 - 2
Thanks again
schlaepfer
by adafruit_support_bill on Thu Feb 14, 2019 1:24 pm
Plugging the numbers into the equation as it is documented gives the correct result:
https://www.arduino.cc/reference/en/lan ... /math/map/
Appendix
For the mathematically inclined, here’s the whole function
long map(long x, long in_min, long in_max, long out_min, long out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
There was some discussion a while back in the Arduino forums regarding the correctness of that implementation. I'm not sure if it has been changed.
