How many panels can I use with RGB MATRIX HAT
by beb on Thu Feb 14, 2019 12:59 pm
I want to make a display of 32х16 panels.
I want to use a matrix like this:
[32x16][32x16][32x16][32x16][32x16]
Can i use a RGB MATRIX HAT with Pi 3 model B+?
The picture will be static with 10 sec change.
beb
Re: How many panels can I use with RGB MATRIX HAT
by adafruit_support_carter on Thu Feb 14, 2019 3:53 pm
Wow, that's a big display. While you can chain displays with the matrix HAT, things get tricky once you exceed a few panels. In the guide:
https://learn.adafruit.com/adafruit-rgb ... i/overview
we mention only testing up to 32x128 (4 panels).
It won't be as simple as chaining all those displays together and connecting them to the HAT, unfortunately.
by beb on Thu Feb 14, 2019 4:00 pm
Any idea I can do this ?
Use a controller/hub for the panels ?
beb
by adafruit_support_carter on Thu Feb 14, 2019 4:13 pm
When you get to something that size, the power management becomes non-trivial. You could use the HAT as a way to connect to the matrix array and provide the signal. But it would not be able to directly power all those displays.
by beb on Thu Feb 14, 2019 4:27 pm
Oh, power is not a question, for sure I’ll use external. I am worried about the signal.
How should I connect the matrix of panels.
beb
by adafruit_support_carter on Thu Feb 14, 2019 4:36 pm
In general, just chain them with the ribbon cable. Each has an input and output:
https://learn.adafruit.com/32x16-32x32- ... new-wiring
This older guide, which pre-dates the HAT, shows one example:
https://learn.adafruit.com/16x32-rgb-di ... 2/overview
by beb on Thu Feb 14, 2019 4:40 pm
Ty for a reply, I’ll try any tell the result.
beb
by adafruit_support_carter on Fri Feb 15, 2019 12:33 am
Awesome. If you get this working, I'm sure there are others out there that would love to see the details. Good luck with the project.
