Screen shifted (TVP401)
by thatguy1 on Fri Feb 15, 2019 6:29 pm
I am using the TVP401 in a project, I am not using an adafruit screen, but one I got online because I needed a specific size.
When I plug in a regular HDMI source, PC, PS4, etc it displays properly. When I use the raspberry pi, everything is shifted to the left. If I adjust the overscan right option in config.txt to 80, I can shift it so it shows the entire picture, but adjusting the other overscan options won't move the image to fill the screen. I used the config.txt code from https://learn.adafruit.com/adafruit-tfp401-hdmi-slash-dvi-decoder-to-40-pin-ttl-display/raspberry-pi-config here to get it this far.
what else can I do? I know it's a 800x480 screen, but I do not know the timings.
here is a pic
here is the screen in question
https://www.aliexpress.com/item/6-2-inch-HD-car-LCD-screen-with-40P-cable-for-TIANMA-TM062RDZ02/1254466597.html?spm=a2g0s.9042311.0.0.24a94c4dnT3cOH
thatguy1
Re: Screen shifted (TVP401)
by thatguy1 on Sun Feb 17, 2019 1:38 pm
I've got the screen centered, and no matter what I've done, I can't get it to fill the screen. the right side is always empty, or loaded with artifacts.
here are my overscan settings to get this far.
overscan_left=150
#overscan_right=16
overscan_top=1
overscan_bottom=16
thatguy1
