Set backlight brightness on HDMI 5" 800x480 Display Backpack
by marsroverdriver on Sun Feb 17, 2019 6:43 pm
I'm making an alarm clock using the HDMI 5" 800x480 Display Backpack - With Resistive Touchscreen (product ID 2260). It's great, but it's awfully bright in the middle of the night. Can I adjust the backlight brightness from Linux? (I'm driving it with a Raspberry Pi 0.)
When xbacklight had no effect, I tried setting the gamma -- but neither xgamma nor xrandr's gamma-setting functionality had any effect, either. (I am running an X server, not going direct to the framebuffer, in case you're wondering. :-) The /sys/class/backlight/ directory appears to be empty, which is probably not a good sign. :-/
How should I do this?
marsroverdriver
Re: Set backlight brightness on HDMI 5" 800x480 Display Back
by adafruit_support_carter on Tue Feb 19, 2019 2:10 pm
For HDMI, you can not do this unfortunately.
https://learn.adafruit.com/adafruit-5-8 ... /faq#faq-6
by marsroverdriver on Wed Feb 20, 2019 1:12 am
Argh. :-( Well, thanks -- is there info about how to do it on the hardware?
marsroverdriver
by adafruit_support_carter on Wed Feb 20, 2019 2:32 pm
