1.8" Color TFT LCD display with MicroSD Card Breakout: Stop
by FVA1 on Tue Feb 19, 2019 12:52 pm
I bought 2 of the 1.8" Color TFT LCD display with MicroSD Card Breakout - ST7735R LCD's but the one is not OK. After some time maybe 1 hour the graphic images on it gets messed up, but the text stays OK for a short while until just a white screen is present. If I leave it for a couple of hours it will again work but will fail again. I just unplug the faulty one and then fit the other unit I have and all stays OK. Bought them on the 9 Feb 2019
FVA1
Re: 1.8" Color TFT LCD display with MicroSD Card Breakout: S
by adafruit_support_carter on Tue Feb 19, 2019 2:56 pm
Can you recreate the issue using the graphicstest demo from the library?
https://github.com/adafruit/Adafruit-ST ... cstest.ino
by FVA1 on Tue Feb 19, 2019 3:25 pm
I uploaded your sketch but just white screen. On the working unit I have your test is working. Will leave the unit off for a couple of hours and then test again, as it recover after some time if its not hooked up.
FVA1
by FVA1 on Wed Feb 20, 2019 7:47 am
Left it overnight. after Power ON, it worked and the Media buttons where changing for about 15min. Then just froze, did a reset and after that only white screen.
FVA1
by adafruit_support_carter on Wed Feb 20, 2019 1:42 pm
OK, so it does it also with the demo sketch. Thanks for testing that. Can you post a photo of the backside of the problematic display. It can be disconnected from the wiring, just want to check for anything obvious on the board.
by FVA1 on Wed Feb 20, 2019 2:11 pm
Sorry picture not that good. Can take a better one tomorrow during daytime.
FVA1
by FVA1 on Wed Feb 20, 2019 2:36 pm
Hi, I noticed that when observing the Serial data that when the Display stop working it prints (File not found). After a reset (Initializing SD card...failed) that's when loading images from SD card. With your test shows (done) but screen stays white.
FVA1
by adafruit_support_carter on Wed Feb 20, 2019 3:56 pm
Thanks for the photo. That all looks OK.
For the test I linked, it will print "Done" and then go into an infinite loop that just inverts the display over and over:
https://github.com/adafruit/Adafruit-ST ... t.ino#L140
It sounds like you display did that? But only for 15 minutes?
by FVA1 on Thu Feb 21, 2019 9:28 am
Yes, infinite loop for about 15 min then stopped.
If I then cut the power to it for couple of hours, it will again worked but just for a while. The other LCD function without a problem at all.
FVA1
by adafruit_support_carter on Thu Feb 21, 2019 12:56 pm
Sounds like some weird thermal issue. Something very marginal is becoming unhappy once it warms up. Then is OK again once it cools down.
Just to be clear - in your swap out testing with the other display, the only change is the display itself. Everything else is the same? Same cables, connections to main board, etc?
by FVA1 on Thu Feb 21, 2019 1:11 pm
Yes, everything is the same, I just unplug it and plug the other unit in. I re-soldered the 10way pins on it, but stays the same.
FVA1
by adafruit_support_carter on Thu Feb 21, 2019 1:20 pm
OK, let's replace it. Send an email to support@adafruit.com with a link to this thread and your order number and they can send you a new display.
by FVA1 on Thu Feb 21, 2019 1:57 pm
FVA1
