RGB Matrix prevent IR receiver to work
Alkerion
Post by Alkerion »
Hi !
I've a project with a RGB Matrix 64x32 and an IR Receiver connected to an Arduino Mega 2560 board.
I can't get the IR to read the correct values if the Matrix is activated.
The IR is working perfect until I call :
matrix.begin();
I've tried a lot of different Pins for the IR signal : Digital, Analog, PWN.... on different ports than the Matrix, etc. haven't been able to get it to work.
Any idea why this Matrix function is preventing the IR receiver to works ?
Regards
adafruit_support_mike
Re: RGB Matrix prevent IR receiver to work
What kind of IR receiver are you using?
Alkerion
Post by Alkerion »
I'm using a 38kHz TSOP4838 Module.
It works perfect until I call matrix.begin();
Regards
Thank you. As a sanity check, what pins are you using for the TSOP4838?
Alkerion
Post by Alkerion »
5v, gnd, and for signal I tried nearly all remaining available pins.
Alkerion
Post by Alkerion »
Hi !
Any clues as to why it doesn't work ?
Regards
Sorry for the delay.
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
The two most likely options for the source of the trouble will be light interference from the RGB matrix or voltage spikes in the supply lines.
Alkerion
Post by Alkerion »
Hi !
I don't think it could be due to light interference.
- The IR module is working perfect until I call matrix.begin();
- The IR module is behind the matrix
- The issue is happening event when matrix is powered off
The matrix and the MC each have a dedicated power source.
I'm leaning more for a concern about a resource sharing conflict between libraries.
Hmm.. are you using interrupts to read the state of the TSOP38238’s output. That’s about the only way you could get anything other than a pin conflict.
Alkerion
Post by Alkerion »
This is what I'm doing :
#include <IRremote.h>
int RECV_PIN = 9;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup()
	irrecv.enableIRIn(); // Start the receiver
	if (irrecv.decode(&results)) {
		Serial.println(results.value, HEX);
		if (results.value == 0xC101E57B) {
			Serial.println("1");
		irrecv.resume(); // Receive the next value
I've tried with interrupt, same behavior :
int RECV_PIN = 2;
void setup()
attachInterrupt(0, IRorders, CHANGE);
delay(500);
void IRorders() {
		Serial.println(results.value, HEX); //Normally we should not have Serial output in an interrupt, just here for test purpose
What else ?
The RGB Matrix library does use a timer interrupt which is initialized in the begin(). The ISR calls the updateDisplay() function which looks like it takes a non-trivial amount of time. I suspect it may be long enough to interfere with any IR receiver timing.
Alkerion
Post by Alkerion »
Is there anything we can do to fix that ?
These really need either a dedicated processor - or something with more horsepower and resources than an Arduino. The Atmega processors only have one level of interrupts so mixing time-critical tasks like IR decoding with processor intensive tasks like display refresh is not likely to work.
As it says in the product description:
Keep in mind that these displays are designed to be driven by FPGAs or other high speed processors: they do not have built in PWM control of any kind. Instead, you're supposed to redraw the screen over and over to 'manually' PWM the whole thing. On a 16 MHz Arduino Mega, we managed to squeeze 12-bit color (4096 colors) with 40% CPU usage but this display would really shine if driven by any FPGA, CPLD, Propeller, XMOS or other high speed multi-core controller.
