Sevem Segment display last digit not working
by goveil1 on Wed Jun 12, 2019 4:25 pm
It may be my soldering, but the whole of "digit 4" of the display is not working. All the others work great but this last digit is completely inactive.
Given that, its either defective or the common anode (cathode?) is not soldered correctly to the backpack.
Any ideas?
It is the Adafruit 1.2" 7 segment display with HT16K33 backpack.
Thanks (even an idea of which pin would cause the entire digit to remain out would help)
goveil1
Re: Sevem Segment display last digit not working
by adafruit_support_bill on Wed Jun 12, 2019 4:27 pm
If you post some photos of your soldering, we'll check it out.
The pins that control the digits are on the end with the colon.
by goveil1 on Wed Jun 12, 2019 5:25 pm
IMG_3188 (Copy).jpg (61.63 KiB) Viewed 67 times
IMG_3186 (Copy).jpg (80.57 KiB) Viewed 67 times
Here are the photos == showing problem and the two ends....
IMG_3192 (Copy).jpg (54.96 KiB) Viewed 67 times
goveil1
by goveil1 on Wed Jun 12, 2019 5:30 pm
IMG_3193 (Copy).jpg (72.98 KiB) Viewed 67 times
IMG_3190 (Copy).jpg (63.9 KiB) Viewed 67 times
IMG_3189 (Copy).jpg (67.63 KiB) Viewed 67 times
Some more photos of the soldering
goveil1
by adafruit_support_bill on Wed Jun 12, 2019 7:46 pm
I don't see any problems with the soldering. What code are you using to test with?
by goveil1 on Fri Jun 14, 2019 8:28 pm
Now I am totally embarrassed! I was using Quadalpha and I see now I should be using 7 Segment. I apologize for wasting your time.
It is working now....
goveil1
by adafruit_support_bill on Sat Jun 15, 2019 5:32 am
Good to hear. Thanks for the update.
