NeoPixel 1/4 60 Ring Problem
Ashton19
Post by Ashton19 »
I purchased NeoPixel 1/4 60 Ring but only the first board of led is working, the other 3 board is not working. But when I test them individually all 4 board is okay.
I used RGBWstrandtest from the library. Power supply and soldering joints are okay too.
I connect 3 DIN-DOUT, Left one DIN-DOUT Open. This DIN pin is connected to Arduino D6
I am wondering what I am doing wrong?
kcl1s
Re: NeoPixel 1/4 60 Ring Problem
Post by kcl1s »
To rule out the obvious you did increase the NUMPIXELS to 60 in your code? Other than that with all sections testing good, it has to be a connection issue. Maybe re-flow all the solder joints. Test all the segment connections for continuity. Make sure the broken signal connection foil pads are not touching.
Fellow hobbyist
Keith
Ashton19
Post by Ashton19 »
kcl1s wrote:To rule out the obvious you did increase the NUMPIXELS to 60 in your code? Other than that with all sections testing good, it has to be a connection issue. Maybe re-flow all the solder joints. Test all the segment connections for continuity. Make sure the broken signal connection foil pads are not touching.
Fellow hobbyist
Keith
Yes, I changed to 60. Soldered and desoldered the connection a couple of times, Individually every board is working.
kcl1s
Post by kcl1s »
What happens if you move the signal temporarily around to the next segment?
Keith
adafruit_support_carter
Can you clarify what this means? Are you doing as suggested above and connecting directly to each segment?
Ashton19
Post by Ashton19 »
When I connect each PCB individually after desoldering. each one worked. But when I solder them together only first PCB lit up.
Is this your starting point for the ring? For where you hook up the input wires. And the connection circled is not soldered?
Ashton19
Post by Ashton19 »
adafruit_support_carter wrote:Is this your starting point for the ring? For where you hook up the input wires. And the connection circled is not soldered?
Yes, This is my starting point. I left it disconnected. I connect L shaped pin-header in DIN from which I use a jumper wire to Arduino.
Your other photo of your segment-to-segment solder connection looks OK. Is that the current state of the solder connection at the first segment junction?
Also, post your complete code. Let's double check it's not something simple like the number of pixels, even though you mention changing that.
