Gemma M0 Test Code for Neopixels
Re: Gemma M0 Test Code for Neopixels
by jeremyzschau on Sat Aug 31, 2019 9:00 pm
Typing the commands in the serial window does cause the neopixel to turn red. I just did it again.
Screen Shot 2019-09-01 at 9.53.14 AM.png (147.47 KiB) Viewed 127 times
jeremyzschau
by adafruit_support_carter on Tue Sep 03, 2019 12:41 pm
Cool, so the hardware is still functional. In the code you were having issues with, take a close look at what pin you are specifying for the NeoPixel pin.
by jeremyzschau on Tue Sep 03, 2019 4:46 pm
The D1 pin.
jeremyzschau
by adafruit_support_carter on Tue Sep 03, 2019 5:38 pm
by jeremyzschau on Tue Sep 03, 2019 6:00 pm
This is the code as of now.
# Simple test for NeoPixels on Raspberry Pi
import time
import board
import neopixel
# Choose an open pin connected to the Data In of the NeoPixel strip, i.e. board.D18
# NeoPixels must be connected to D10, D12, D18 or D21 to work.
pixel_pin = board.D1
# The number of NeoPixels
num_pixels = 1
# The order of the pixel colors - RGB or GRB. Some NeoPixels have red and green reversed!
# For RGBW NeoPixels, simply change the ORDER to RGBW or GRBW.
ORDER = neopixel.GRB
pixels = neopixel.NeoPixel(pixel_pin, num_pixels, brightness=0.2, auto_write=False,
                           pixel_order=ORDER)
def wheel(pos):
    # Input a value 0 to 255 to get a color value.
    # The colours are a transition r - g - b - back to r.
    if pos < 0 or pos > 255:
        r = g = b = 0
    elif pos < 85:
        r = int(pos * 3)
        g = int(255 - pos*3)
        b = 0
    elif pos < 170:
        pos -= 85
        r = int(255 - pos*3)
        g = 0
        b = int(pos*3)
    else:
        pos -= 170
        r = 0
        g = int(pos*3)
        b = int(255 - pos*3)
    return (r, g, b) if ORDER == neopixel.RGB or ORDER == neopixel.GRB else (r, g, b, 0)
def rainbow_cycle(wait):
    for j in range(255):
        for i in range(num_pixels):
            pixel_index = (i * 256 // num_pixels) + j
            pixels[i] = wheel(pixel_index & 255)
        pixels.show()
        time.sleep(wait)
while True:
    # Comment this line out if you have RGBW/GRBW NeoPixels
    pixels.fill((255, 0, 0))
    # Uncomment this line if you have RGBW/GRBW NeoPixels
    # pixels.fill((255, 0, 0, 0))
    pixels.show()
    time.sleep(1)
    pixels.fill((0, 255, 0))
    # pixels.fill((0, 255, 0, 0))
    pixels.show()
    time.sleep(1)
    pixels.fill((0, 0, 255))
    # pixels.fill((0, 0, 255, 0))
    pixels.show()
    time.sleep(1)
    rainbow_cycle(0.001)    # rainbow cycle with 1ms delay per ste
jeremyzschau
by adafruit_support_carter on Tue Sep 03, 2019 6:04 pm
What filename are you saving that as?
by jeremyzschau on Wed Sep 04, 2019 3:30 am
The file is saved as backup_code.py.
jeremyzschau
by adafruit_support_carter on Wed Sep 04, 2019 10:04 am
Only files with a certain name are run automatically:
https://learn.adafruit.com/welcome-to-c ... -file-7-32
Try changing the name to code.py
by jeremyzschau on Wed Sep 04, 2019 9:33 pm
Thank you so much for your infinite patience Mr. Carter. It worked with the alligator clip gemma and with the gemmas with 8 neopixels sewn with conductive thread. Hopefully anyone using a Mac can use these steps as a guide. Now that I have code that works I can complete sewing the scarves.
1. (first time only) double click gemma drag adafruit-circuitpython-gemma_m0-en_US-4.0.2.uf2 file into gemma.
2. Mu Editor on Mac file chosen neopixel_simpletest.py
3. save file as code.py
goal: single neopixel rainbow cycle
Bundle Version py
rm -rf /Volumes/CIRCUITPY/lib
mkdir /Volumes/CIRCUITPY/lib
cp -X ./lib/adafruit_dotstar.mpy /Volumes/CIRCUITPY/lib/
ls /Volumes/CIRCUITPY/lib/*
Mu Editor in Serial Window
import board
import adafruit_dotstar
led = adafruit_dotstar.DotStar(board.APA102_SCK, board.APA102_MOSI, 1)
led.fill(0x0000ff)
Copy file one at a time cp command
cp
Terminal
mdutil -i off /Volumes/CIRCUITPY
cd /Volumes/CIRCUITPY
rm -rf .{,_.}{fseventsd,Spotlight-V*,Trashes}
mkdir .fseventsd
touch .fseventsd/no_log .metadata_never_index .Trashes
cd -
delete extra cd if after jeremy$
cd ~
cd Desktop
cd adafruit-circuitpython-bundle-4.x-mpy-20190819
This means sitting in the library bundle directory.
jeremy-zschaus-computer-2:adafruit-circuitpython-bundle-py-20190807
cp -X ./lib/neopixel.mpy /Volumes/CIRCUITPY/lib/
import board
import neopixel
pixel = neopixel.NeoPixel(board.D1, 1)
pixel.fill(0xFF0000)
Mu Editor Paste in main code window
examples/neopixel_rpi_simpletest.py
import time
import board
import neopixel
num_pixels = 1
pixels = neopixel.NeoPixel(pixel_pin, num_pixels, brightness=0.2, auto_write=False, pixel_order=ORDER)
def wheel(pos):
        r = g = b = 0
    elif pos < 85:
        r = int(pos * 3)
        b = 0
    elif pos < 170:
        pos -= 85
        g = 0
        b = int(pos*3)
    else:
        pos -= 170
        r = 0
        g = int(pos*3)
        pixels.show()
        time.sleep(wait)
while True:
    pixels.show()
    time.sleep(1)
    pixels.show()
    time.sleep(1)
    pixels.show()
    time.sleep(1)
    rainbow_cycle(0.001)    # rainbow cycle with 1ms delay per step
Screen Shot 2019-09-05 at 10.23.11 AM.png (209.03 KiB) Viewed 56 times
jeremyzschau
by adafruit_support_carter on Thu Sep 05, 2019 2:25 pm
Yeah! Awesome. Hope the scarves come together OK. Have fun!
