Gemma M0 Test Code for Neopixels
Re: Gemma M0 Test Code for Neopixels
by jeremyzschau on Wed Aug 14, 2019 7:11 pm
lib folder is in adafruit-circuitpython-bundle-py-20190807 folder which is on desktop.
desktop/adafruit-circuitpython-bundle-py-20190807/lib
jeremyzschau
by adafruit_support_carter on Wed Aug 14, 2019 8:22 pm
OK, let's see if we can cd into that directory. Try these commands:
cd ~
cd Desktop
cd adafruit-circuitpython-bundle-py-20190807
by jeremyzschau on Thu Aug 15, 2019 8:18 pm
Here.
Screen Shot 2019-08-16 at 9.12.35 AM.png (344.27 KiB) Viewed 148 times
jeremyzschau
by adafruit_support_carter on Thu Aug 15, 2019 9:31 pm
the first command is:
cd ~
not:
cd -cd~
by jeremyzschau on Thu Aug 15, 2019 9:48 pm
Something new.
Screen Shot 2019-08-16 at 10.42.02 AM.png (440.33 KiB) Viewed 139 times
jeremyzschau
by adafruit_support_carter on Thu Aug 15, 2019 10:49 pm
Looks good so far. Press enter for the last command.
by jeremyzschau on Thu Aug 15, 2019 10:56 pm
This?
Screen Shot 2019-08-16 at 11.50.00 AM.png (76.57 KiB) Viewed 132 times
jeremyzschau
by adafruit_support_carter on Thu Aug 15, 2019 11:07 pm
OK, now you are sitting in the library bundle directory.
Now type this command:
cp -X ./lib/adafruit_dotstar.mpy /Volumes/CIRCUITPY/lib
by jeremyzschau on Sat Aug 17, 2019 1:30 am
Please check.
Screen Shot 2019-08-17 at 2.23.47 PM.png (211.15 KiB) Viewed 100 times
jeremyzschau
by adafruit_support_carter on Mon Aug 19, 2019 12:20 pm
Sorry, I missed another detail. Your are working with the wrong .zip file from the bundle. You have the one with the .py source files, not the .mpy compiled versions, which is what you want. On the bundle release page:
https://github.com/adafruit/Adafruit_Ci ... e/releases
you want the one that has "mpy" in the name. And then match the version number with the version of CP you are using. For example, if you are using CircuitPython 4.x, download this zip file:
by jeremyzschau on Mon Aug 19, 2019 7:20 pm
Please check.
Screen Shot 2019-08-20 at 8.14.22 AM.png (259.17 KiB) Viewed 76 times
jeremyzschau
by adafruit_support_carter on Mon Aug 19, 2019 7:45 pm
OK. That looks good. It look like you were able to successfully copy the adafruit_dotstar.mpy file to the Gemma M0 board. So now you can go back to Mu and try running the little dotstar example:
Screenshot from 2019-08-06 07-25-17.png (84.84 KiB) Viewed 71 times
by jeremyzschau on Mon Aug 19, 2019 7:58 pm
Please check.
Screen Shot 2019-08-20 at 8.53.07 AM.png (66.35 KiB) Viewed 68 times
jeremyzschau
by adafruit_support_carter on Mon Aug 19, 2019 9:25 pm
Weird. Why isn't it finding it? Let's make sure it's there. Try going back to the command line and running this command.
ls /Volumes/CIRCUITPY/lib
That command will list the contents of the lib folder so we can see what's there.
by jeremyzschau on Mon Aug 19, 2019 9:33 pm
Please check.
Screen Shot 2019-08-20 at 10.27.54 AM.png (70.27 KiB) Viewed 62 times
jeremyzschau
