Gemma M0 Test Code for Neopixels
Re: Gemma M0 Test Code for Neopixels
by adafruit_support_carter on Mon Aug 19, 2019 10:17 pm
That one isn't a Python command. It's a linux command, so run it back out in the command line here:
by jeremyzschau on Mon Aug 19, 2019 10:22 pm
Please check.
Screen Shot 2019-08-20 at 11.16.49 AM.png (72.88 KiB) Viewed 182 times
jeremyzschau
by adafruit_support_carter on Tue Aug 20, 2019 12:52 am
OK. And now:
ls /Volumes/CIRCUITPY/lib/*
by jeremyzschau on Tue Aug 20, 2019 1:33 am
Please check.
Screen Shot 2019-08-20 at 2.27.54 PM.png (80 KiB) Viewed 171 times
jeremyzschau
by adafruit_support_carter on Tue Aug 20, 2019 12:42 pm
Hmmmm. Ok, I think what is happening at this point is that you've somehow created /Volumes/CIRCUITPY/lib, but it's not actually a folder. Looking at the icon here:
it looks like it might be a file instead.
Here is a series of commands to delete it, then re-create it as a folder, re-do the copy of the library file, and a final ls to verify that it's there:
rm -rf /Volumes/CIRCUITPY/lib
mkdir /Volumes/CIRCUITPY/lib
cp -X ./lib/adafruit_dotstar.mpy /Volumes/CIRCUITPY/lib/
by jeremyzschau on Tue Aug 20, 2019 9:31 pm
Please check.
Screen Shot 2019-08-21 at 10.25.20 AM.png (979.43 KiB) Viewed 152 times
jeremyzschau
by adafruit_support_carter on Tue Aug 20, 2019 11:15 pm
Excellent. That's looking better. Now try the DotStar example again:
Screenshot from 2019-08-06 07-25-17.png (84.84 KiB) Viewed 146 times
by jeremyzschau on Tue Aug 20, 2019 11:47 pm
The large LED on the gemma is now blue.
Screen Shot 2019-08-21 at 12.41.07 PM.png (204.43 KiB) Viewed 144 times
jeremyzschau
by adafruit_support_carter on Wed Aug 21, 2019 11:36 am
Yeah! So it's all working now for the DotStar. You can play around changing it to other colors if you want. Here's red:
led.fill(0xFF0000)
and green:
led.fill(0x00FF00)
Once you're done playing around with that, go back and see if you can copy over the neopixel library and then we can try getting the NeoPixel to work.
by jeremyzschau on Wed Aug 21, 2019 10:40 pm
The red and green colors on the large gemma LED worked.
Screen Shot 2019-08-22 at 11.34.47 AM.png (323.07 KiB) Viewed 121 times
jeremyzschau
by adafruit_support_carter on Thu Aug 22, 2019 11:12 am
You'll need to copy over the neopixel library. There are two things to remember. Since you are using a non-Express board there isn't enough room for the entire library bundle (i.e. the lib folder in the bundle zip file), so you'll have to copy each library one at a time:
https://learn.adafruit.com/welcome-to-c ... ards-12-27
And since you are on a Mac, you'll have to use the cp command to prevent Mac OS from also copying over a lot of Mac OS bloat:
https://learn.adafruit.com/welcome-to-c ... ards-20-39
This is the same general process you followed above to copy over the DotStar library.
by jeremyzschau on Thu Aug 22, 2019 8:13 pm
I'm sorry after reading everything from the two links I do not understand what to follow and what to ignore. Can you please post exactly what I need to do?
Screen Shot 2019-08-23 at 9.11.02 AM.png (592.36 KiB) Viewed 106 times
jeremyzschau
by adafruit_support_carter on Thu Aug 22, 2019 8:53 pm
Get back to your command line to where you are sitting in the same location as here:
and then you should be able to just run:
cp -X ./lib/neopixel.mpy /Volumes/CIRCUITPY/lib/
to copy over the NeoPixel library.
by jeremyzschau on Thu Aug 22, 2019 9:02 pm
Please check.
Screen Shot 2019-08-23 at 9.56.33 AM.png (355.56 KiB) Viewed 94 times
jeremyzschau
by adafruit_support_carter on Thu Aug 22, 2019 9:32 pm
OK, we can try the external NeoPixel(s) now. Post another photo showing how they are currently wired to the Gemma. Want to make sure we use the correct pins.
