Uncanny eyes not displaying properly
by dhoffstetter on Sat Aug 03, 2019 7:17 pm
I am using a Teensy3.2 along with TFT display to run the uncanny eyes project. The eyes are not displayed properly - there is no color and they are offset. There is animation. I know the TFT displays are okay because they worked with the Raspberry Pi snake eyes bonnet.
I re-wired the eyes (twice) from scratch with the same result.
The only change I made to the config.h file was to comment out the OLED library and add the TFT one.
Other info..
Mac 10.14.5
Arduino 1.8.9
Teensyduino 1.4.6
Adafruit libraries (from library manager):
Adafruit GFX 1.5.6
Adafruit ST7735 1.4.0
Adafruit Zero DMA 1.0.4
Any suggestions to fix this would be appreciated. Thanks!
Diane
dhoffstetter
Re: Uncanny eyes not displaying properly
by jim_lee on Sun Aug 04, 2019 11:42 pm
What's your clock speed set at? 9x overclocking (the default) probably won't work.
-jim lee
jim_lee
by dhoffstetter on Sun Aug 04, 2019 11:58 pm
Hi Jim,
Per the instructions, I set the clock to 72MHz.
Diane
dhoffstetter
by adafruit_support_carter on Tue Aug 06, 2019 1:04 pm
Can you post a photo that also shows the wiring connection to the Teensy.
by dhoffstetter on Tue Aug 06, 2019 1:14 pm
Here are the pictures.
dhoffstetter
by adafruit_support_carter on Tue Aug 06, 2019 1:35 pm
Looks a little different than first photo. Only right eye? That's OK, let's just test the displays individually.
With that setup, try running the graphictest demo from the ST7735 library:
https://github.com/adafruit/Adafruit-ST ... cstest.ino
making the necessary pin changes here:
https://github.com/adafruit/Adafruit-ST ... st.ino#L69
by dhoffstetter on Wed Aug 07, 2019 7:09 pm
I forgot to mention when I sent the pictures that I rewired with just one screen.
I will try the tests that you suggested and let you know the results.
Diane
dhoffstetter
by dhoffstetter on Wed Aug 07, 2019 8:48 pm
I think that I found the problem.
When I ran the graphic test demo, I saw the same issue. But then I updated the graphic test code to use the ST7789 (which is what I have). The display worked as expected.
The uncanny eyes code that I have does not support the ST7789. I just assumed that since it worked with the RPi code, that the same displays would work with this code with the Teensy.
I assume that I can update the code to work with ST7789. If not, please let me know before I spend the time to do it.
Thanks for your help.
Diane
dhoffstetter
by adafruit_support_carter on Thu Aug 08, 2019 11:40 am
You might be able to, but the code is pretty optimized. So it might take some doing to make sure all the subtle #def's etc. are taken care of.
by XRAD on Sat Aug 10, 2019 9:31 am
as Carter says. I was able to get a single eye to function well on the ST7789:
Re: HalloWing Audio
by XRAD on Sun Oct 21, 2018 2:54 am
Just as an update: I have moved most of the code for uncannyeyes via C++ to a teensy, which runs an adafruit 1.44 or 1.8 LCD no issues. I just needed to #include <Adafruit_ST7789.h>. You can carefully edit all the major functions to get a single canthus minus eye. Remove the logo and paint background black and eye looks great on a 1.8" . Also, I have configured the setup to include neopixels in varoius configs such as running down the row, fade, random flash, and a basic fire glow.
viewtopic.php?f=57&t=142444#p704229
XRAD
by dhoffstetter on Sat Aug 10, 2019 9:43 am
Thanks for the info. I will check it out!
Diane
dhoffstetter
by XRAD on Sun Aug 11, 2019 11:07 am
One thing that makes it easier is to get the adafruit GFX test functioning first on the ST7789, then get the eye going....
XRAD
