Help with wiring up some LEDs
by Razzman70 on Thu Aug 08, 2019 7:37 pm
So I purchased both the slow fade and the fast flashing variants of these LEDs along with a L4931 TO-92 voltage regulator. I got the LEDs to light up on their own off of 3 to 5 volts, but when I run them through the regulator I noticed that they will only be red instead of the RGB pattern. I even tried to use the recommended capacitor but than nothing lights up.
Razzman70
Re: Help with wiring up some LEDs
by franklin97355 on Thu Aug 08, 2019 7:45 pm
What are you using to power the regulator? You need at least 6 volts input for reliable operation.
franklin97355
by Razzman70 on Thu Aug 08, 2019 9:41 pm
I was using 5 volts from a USB power source. I figured this would have been enough since the product page says 4-20 volts.
Razzman70
by franklin97355 on Thu Aug 08, 2019 11:44 pm
That should work. I'll ask if anyone knows why this is happening.
franklin97355
by adafruit2 on Fri Aug 09, 2019 12:22 am
can you post up a photo or your regulator? do you have a scope?
adafruit2
Site Admin
by chemdoc77 on Fri Aug 09, 2019 7:18 pm
Did you measure the output voltage of your voltage regulator with a multimeter or a VOM?
chemdoc77
by Razzman70 on Fri Aug 09, 2019 8:19 pm
adafruit2 wrote:can you post up a photo or your regulator? do you have a scope?
I don't have a photo of the regulator but it is Adafruit product ID 2166. I don't have access to a scope and I just discovered that my cheap harbor freight multimeter is broken, but I did figure out that since I was running these LEDs in a series circuit, standard USB power was not able to supply the current needed. I then tested running the 15 LED's I need in parallel and they did all light up, but the voltage regulator was getting extremely hot, so I might have to figure out a better solution for voltage reduction that can be passively cooled in an enclosed space or find a way to reduce the amperage.
Razzman70
by adafruit2 on Sat Aug 10, 2019 7:43 pm
yep! you're learning lots - keep going :)
adafruit2
Site Admin
