RGB LCD with Backpack
by joshmcintyre on Thu Aug 08, 2019 11:31 pm
I was all excited to use my new LCD, but I realized after soldering everything together per the guide that the RGB character LCDs are not compatible with the I2C backpack :(
Is there anything I can do besides purchase a new backpack and non-RGB LCD screen?
I don't care about the RGB features at all, just the character display. Are there any known "hacks" for the CircuitPython library that would allow me to use what I have on hand?
Another option I can think of would be to de-solder the backpack from the other side of the attached header and then wire it up the "manual" way, but the backpack is certainly convenient which I why I ordered it...
joshmcintyre
Re: RGB LCD with Backpack
by adafruit_support_bill on Fri Aug 09, 2019 5:44 am
The only difference between the RGB and non-RGB versions of the LCD is the backlight. The RGB has 2 extra pins for the G and B channels of the backlight.
If you connect it up directly - ignoring the last two pins, you will have a red backlight. Leaving out the last pin, you could use a jumper to select a red, green or blue backlight.
by joshmcintyre on Fri Aug 09, 2019 10:05 am
Thanks Bill! That makes sense. I get a red backlight no problem.
The reason I posted is that I can't seem to get a message to display using the character display library:
       import adafruit_character_lcd.character_lcd_i2c as character_lcd
        # Initialize the board
        i2c = busio.I2C(board.SCL, board.SDA)
        cols = 20
        rows = 4
        lcd = character_lcd.Character_LCD_I2C(i2c, cols, rows)
        # Display the address or private key passed in
        lcd.message = "Hi"
Am I missing something code wise?
joshmcintyre
by adafruit_support_bill on Fri Aug 09, 2019 10:47 am
Do you see any thing at all displayed?
Try adjusting the contrast pot. (Be gentle, it is easily damaged if you turn it too far.)
by joshmcintyre on Sat Aug 10, 2019 3:28 pm
Hi Bill,
Sorry for the delayed response. I got back to my project last night and all I needed to do was adjust the contrast potentiometer. Everything is working now!
joshmcintyre
by adafruit_support_bill on Sat Aug 10, 2019 4:45 pm
Good to hear. Thanks for the update!
