Mini Skinny RGB NeoPixel 4 wire connection?
by seefar on Fri Aug 09, 2019 6:59 pm
I've just ordered in some 60/m Mini Skinny NeoPixel strip and am not sure how I should connect to the wires that come soldered on to the strip (two wires go to a 2pin JST and the other two are bare).
It looks like the strip has the normal + / - / D pads which has the 4 wires and 2-pin JST throwing me off.
I haven't been able to find any detail on this (at least that I'm following) on the product page or forum. I wanted to double-check before accidentally frying the strip.
Thanks for any help,
Clayton
seefar
Re: Mini Skinny RGB NeoPixel 4 wire connection?
by adafruit_support_mike on Sat Aug 10, 2019 4:07 am
The free wires connect to the strip's 5V and GND rails.
The wires that go into the JST connector are for the data signal.. you need a data line and a GND line for that connection.
by seefar on Sat Aug 10, 2019 9:38 am
Thanks Mike.
When soldering new wires to the pads, at cuts, later can you simply use 3 wires (5v, ground, and one for data) – or do you need to do something special for the data pad with an extra ground wire?
seefar
by adafruit_support_bill on Sat Aug 10, 2019 9:56 am
When splicing strips, connect power ground and 5v from the last pixel of one strip to the first pixel of the next. If you have a lot of pixels (more than 100 or so) you should feed +5v and GND to both ends of the strip. If you have several hundred or more, you should feed power to several points along the strip.
https://learn.adafruit.com/adafruit-neo ... power-5-17
