RGBMatrix, RGBMatrixOptions - asking for daemon password
by DebraPeri on Tue Aug 13, 2019 2:08 pm
I stumbled across a very strange thing with the python libs for the LED RGB matrix display. When I create an instance of RGBMatrix (see code below) I am prompted for a password for user 'daemon'. This code is part of a python script that accesses the bluetooth services so it has to run as root. I haven't done an exhaustive search through the rgbmatrix code but did notice that when the demos are run they appear as being owned by user 'daemon'. Where does that su occur? Can I get around this? Do I need to recompile the libraries with a different option? I''m stumped. Any help is appreciated.
Thanks,
Debra Peri
from rgbmatrix import RGBMatrix, RGBMatrixOptions
def setup_RGB_matrix():
    logging.warning('Setting up LED RGB matrix  ...')
    options = RGBMatrixOptions()
    options.rows = 32
    options.cols = 32
    options.chain_length = 1
    options.parallel = 1
    options.row_address_type = 0
    options.multiplexing = 0
    options.pwm_bits = 11
    options.brightness = 100
    options.pwm_lsb_nanoseconds = 130
    options.show_refresh_rate = 1
    options.gpio_slowdown = 1
    options.disable_hardware_pulsing = True
    matrix = RGBMatrix(options = options)
running as root the call to create an instance of RGBMatrix prompts for a password for user 'daemon'
Screen Shot 2019-08-13 at 10.58.39 AM.png (598.74 KiB) Viewed 160 times
demo code running as user 'daemon'
Screen Shot 2019-08-13 at 10.58.14 AM.png (582.37 KiB) Viewed 160 times
DebraPeri
Re: RGBMatrix, RGBMatrixOptions - asking for daemon password
by adafruit_support_carter on Thu Aug 15, 2019 4:04 pm
Not sure. If you run a
whoami
before the sudo, what does it show as the user?
by DebraPeri on Thu Aug 15, 2019 4:40 pm
This is running on a Raspberry Pi, so the user is 'pi' before invoking sudo.
pi@pi-abcs:~ $ whoami
pi
pi@pi-abcs:~ $ id
uid=1000(pi) gid=1000(pi) groups=1000(pi),4(adm),20(dialout),24(cdrom),27(sudo),29(audio),44(video),46(plugdev),60(games),100(users),101(input),108(netdev),997(gpio),998(i2c),999(spi
When I su into root and run the python script I am still prompted for a password. The UDP debug message comes from code that is executed after creating an instance of an RGBMatrix object (after setting the options, matrix = RGBMatrix(options = options) ), so it appears that it's creating a separate thread (which is sending the "285.1Hz" messages to the console.
As root, starting the script:
root@pi-abcs:/home/pi/dev/bluetooth/abcs-muse# ./abcs.py
 273.0Hz*************************     MAIN      ************************************************
 285.1Hz('*** Testing UDP ', 0)
 286.9Hz('*** Testing UDP ', 1)
 286.8Hz('*** Testing UDP ', 2)
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
[sudo] password for  287.4Hz
Any help is deeply appreciated. The project is for capturing EEG signals from a Muse headband that I want to control the RGB LED display. I hope to use more of these RGB LED displays in other projects so it's very helpful for me to know how to use the supplied libraries correctly. Thanks for your help!
DebraPeri
by adafruit_support_carter on Thu Aug 15, 2019 5:30 pm
Can you provide more details on the hardware. What RGB matrix are you using? How is it connected to the Pi?
by DebraPeri on Thu Aug 15, 2019 5:50 pm
I'm using the 64x64 RGB LED Matrix display:
https://www.adafruit.com/product/3649
It's connected to the pi with the Adafruit RGB Matrix Bonnet:
https://www.adafruit.com/product/3211
DebraPeri
by adafruit_support_carter on Thu Aug 15, 2019 6:09 pm
Does the basic hardware work per the guide?
https://learn.adafruit.com/adafruit-rgb ... spberry-pi
One thing to make sure with the 64x64 matrix and the Bonnet is to solder close the jumper as described here:
https://learn.adafruit.com/adafruit-rgb ... ep-2982866
Can you get the examples to work?
https://learn.adafruit.com/adafruit-rgb ... mples-4-30
by DebraPeri on Thu Aug 15, 2019 6:11 pm
Yes, all the hardware works and the demo works perfectly.
DebraPeri
by DebraPeri on Thu Aug 15, 2019 6:17 pm
Here's the way I start the demo:
pi@pi-abcs:~/rpi-rgb-led-matrix/examples-api-use $ sudo nice ./demo -D 6 -m 10  --led-rows=64 --led-cols=64 --led-brightness=10
Size: 64x64. Hardware gpio mapping: adafruit-hat
Press <CTRL-C> to exit and reset LEDs
DebraPeri
by adafruit_support_carter on Thu Aug 15, 2019 6:18 pm
Can you share the full code for test_it.py shown in your first post.
by adafruit_support_mike on Thu Aug 15, 2019 6:20 pm
The hezeller code has a command line option '--led-daemon', which makes it run in the background.
That option is usually called from a startup script that launches the code when the RasPi boots.
by DebraPeri on Thu Aug 15, 2019 6:22 pm
And the demo code runs as user 'daemon', which must be happening in the complied demo code:
pi@pi-abcs:~/rpi-rgb-led-matrix/examples-api-use $ ps -ef | grep demo
root      1532   811  0 15:11 pts/1    00:00:00 sudo nice ./demo -D 6 -m 10 --led-rows=64 --led-cols=64 --led-brightness=10
daemon    1536  1532 75 15:11 pts/1    00:01:35 ./demo -D 6 -m 10 --led-rows=64 --led-cols=64 --led-brightness=10
Is there a switch or something that the rgbmatrix libs can run as a different user? It's getting confusing because the demo code needs to run as root via sudo:
pi@pi-abcs:~/rpi-rgb-led-matrix/examples-api-use $ nice ./demo -D 6 -m 10  --led-rows=64 --led-cols=64 --led-brightness=10
Must run as root to be able to access /dev/mem
Prepend 'sudo' to the command
DebraPeri
by DebraPeri on Thu Aug 15, 2019 6:23 pm
adafruit_support_mike wrote:The hezeller code has a command line option '--led-daemon', which makes it run in the background.
I saw that but my code is calling the lib via the python binding. Is there a switch that can be passed via python? I haven't found it.
DebraPeri
by DebraPeri on Thu Aug 15, 2019 6:43 pm
This is all I can find in the python bindings:
Python 2.7.13 (default, Sep 26 2018, 18:42:22)
[GCC 6.3.0 20170516] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import rgbmatrix
>>> opt = rgbmatrix.RGBMatrixOptions()
>>> opt.daemon
>>> opt.daemon = 1
>>> opt.daemon
1
Could this flag be related?
DebraPeri
by DebraPeri on Thu Aug 15, 2019 6:46 pm
When I set that flag, this error message appears in /var/log/auth.log and the program exits.
Aug 15 15:40:30 pi-abcs sudo:       pi : TTY=pts/0 ; PWD=/home/pi/dev/bluetooth/abcs-muse ; USER=root ; COMMAND=./abcs.py
Aug 15 15:40:30 pi-abcs sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Aug 15 15:40:32 pi-abcs sudo: pam_unix(sudo:session): session closed for user root
Aug 15 15:40:35 pi-abcs sudo: pam_unix(sudo:auth): conversation failed
Aug 15 15:40:35 pi-abcs sudo: pam_unix(sudo:auth): auth could not identify password for [daemon]
DebraPeri
by adafruit_support_carter on Thu Aug 15, 2019 7:02 pm
Are you running Python with elevated privileges?
https://github.com/hzeller/rpi-rgb-led- ... he-library
cron
