WS2812b brightness problem
by Freakdoctor on Wed Aug 14, 2019 12:08 pm
Hi all.
I have a little problem with adarfuit library. When my brithness reach 0 the leds stay off, so i have to set brithness and animations between 255 and 1.
Also for some colors like
int MAGENTA[3] = {255, 0, 200};
in breath or blink animations the color becomes red or blue depending witch one has 255 value.
Somebody can explain to me where is my mistake?
Excuse my approximate english i'm french.
Thanks.
Yan.
#include <IRremote.h>
#define PIXEL_PIN 5
#define PIXEL_COUNT 14
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
int RECV_PIN = 10;
unsigned long lastCode;
int up = 5;
int down = 5;
int upperLimit = 255;
int lowerLimit = 1;
int brightness = 85;
int minBrightness = 20;
int fadeAmount = 1;
int interval = 10;
int fadebrightness = 50;
int sparkleUpperLimit;
unsigned long startMillisSparkle;
int flashInterval = 1000;
unsigned int flashLowerLimit = 1;
int flashUpperLimit;
int flashBrightness;
unsigned long startMillisFlash;
int RED[3] = {255, 0, 0};
int GREEN[3] = {0, 255, 0};
int BLUE[3] = {0, 0, 255};
int ORANGE[3] = {255, 127, 0};
int CYAN[3] = {0, 255, 255};
int PINK[3] = {255, 0, 255};
int YELLOW[3] = {255, 255, 0};
int PURPLE[3] = {150, 0 , 255};
int WHITE[3] = {255, 255, 255};
int OFF[3] = {0, 0, 0};
bool sparkle;
bool flash;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup()
  Serial.begin(9600);
  irrecv.enableIRIn();
  pixels.begin();
  colorChange(20, BLUE);
  pixels.setBrightness(85);
  //pixels.clear();
  startMillisSparkle = millis();
  sparkle = false;
  flash = false;
void loop()
  //IR Input
  if (irrecv.decode(&results)) {
    if (results.value == 0xFFFFFFFF)
      results.value = lastCode;
    if (results.value == 0xf710ef)
      lastCode = results.value;
      colorChange(20, RED);
      pixels.setBrightness(brightness);
      pixels.show();
    if (results.value == 0xf7906f)
      colorChange(20, GREEN);
      pixels.show();
    if (results.value == 0xf750af)
      pixels.show();
    if (results.value == 0xf730cf)
      colorChange(20, MAGENTA);
      pixels.show();
    if (results.value == 0xf7b04f)
      colorChange(20, ORANGE);
      pixels.show();
    if (results.value == 0xf7708f)
      colorChange(20, CYAN);
      pixels.show();
    if (results.value == 0xf708f7)
      colorChange(20, PINK);
      pixels.show();
    if (results.value == 0xf78877)
      colorChange(20, YELLOW);
      pixels.show();
    if (results.value == 0xf748b7)
      colorChange(20, PURPLE);
      pixels.show();
    if (results.value == 0xf7c837)
      colorChange(20, WHITE);
      pixels.show();
    if (results.value == 0xf740bf)
      colorChange(20, OFF);
    if (results.value == 0xf700ff)
      increaseFunction();
      Serial.println("brightness= ");
      Serial.println(brightness);
    if (results.value == 0xf7807f)
      decreaseFunction();
    if (results.value == 0xf728d7)
      flash = true;
    if (results.value != 0xf728d7)
      flash = false;
    if (results.value == 0xf7a857)
      sparkle = true;
    if (results.value != 0xf7a857)
      sparkle = false;
    irrecv.resume();
    Serial.println(results.value, HEX);
  // Animation Sparkle
  if (sparkle)
    sparkleUpperLimit = brightness;
    int aInterval = (255 / sparkleUpperLimit) * interval;
    if (millis() - startMillisSparkle  >= aInterval) {
      fadebrightness = fadebrightness + fadeAmount;
      if (fadebrightness <= lowerLimit )
        fadebrightness = lowerLimit;
        fadeAmount = -fadeAmount;
      if (fadebrightness >= sparkleUpperLimit )
        fadebrightness = sparkleUpperLimit;
      pixels.setBrightness(fadebrightness);
      pixels.show();
  //Animation Flash
  if (flash)
    flashUpperLimit = brightness;
    if (millis() - startMillisFlash >= (flashInterval)) {
      startMillisFlash = millis();
      if (flashBrightness <= flashLowerLimit )
        flashBrightness = flashUpperLimit;
      else
        flashBrightness = flashLowerLimit;
      pixels.setBrightness(flashBrightness);
      pixels.show();
void increaseFunction() {
  brightness += up;
  if (brightness >= upperLimit) brightness = upperLimit;
  for (int i = 0; i < PIXEL_COUNT ; i++)
  pixels.show();
void decreaseFunction()
    brightness -= down;
    if (brightness <= lowerLimit) brightness = lowerLimit;
    pixels.show();
void colorChange(int delayTime, int COLOR[])
  for (int i = 0 ; i < PIXEL_COUNT ; i++)
    pixels.setPixelColor(i, COLOR[0], COLOR[1], COLOR[2]);
    pixels.show();
    delay(delayTime);
Freakdoctor
Re: WS2812b brightness problem
by adafruit_support_carter on Wed Aug 14, 2019 1:13 pm
That's the intended behavior. 0 = off, 255 = max brightness.
The three values are the red, green, blue levels. So by changing them, you are changing the color.
