📣📪 🚚 Adafruit will not be shipping USPS orders Monday January 20, 2020 🗓. Expedited USPS orders placed after 11am ET 🕚 Friday January 17 will go out Tuesday January 21 📣📪🚚
Embedded RGB Stip leds with connector
by Mor on Tue Aug 20, 2019 3:45 am
I am new in this technology and search a simple solution.
I am search of led strip Length 60CM(is my favorite, but not must) and maximum high density,
I need the strip connect to my computer (windows 7) USB port (I not have option of external power output).
What the best solution i can use?
I am will be happy the solution be one unit item if is can to be (controller $ strip leds).
How much leds i can use in this length (maximum leds).
I am go to develop my project with C#(.net framework 4.6).
Mor
Re: Embedded RGB Stip leds with connector
by Lekofraggle on Tue Aug 20, 2019 10:28 am
I am not affiliated with Adafruit, but I can guess at a few answers that they may agree with or not. However, I thought I would answer just to get you thinking.
1) I am not aware of directly controlled usb leds. However, it does depend on whether you want to change the colors or just power a strip. If you want to control colors, I think going with one of the small Arduinos may be your best bet. I have one, and it is incredible. Maybe take a look at their trinket as it controls 5v logic level natively.
2) How large depends on the limits of size and power. The more leds, the more power they require.
as for which strips, take a look at [ur= https://www.adafruit.com/product/3776]dotstars[/url] and neopixels. The neopixels are less densely populated though.
You can take a look at the difference here.
There are other people who sell these types of strips, but quality control varies greatly.
Take a look at the tutorialif you have more questions while you await an official response.
Lekofraggle
by Mor on Sun Aug 25, 2019 4:11 am
Thank you.
Any official response?
what about use this strip (https://www.adafruit.com/product/2328) with this cable(https://www.adafruit.com/product/70).
It is possible?
Mor
by adafruit_support_mike on Sun Aug 25, 2019 3:01 pm
If you need to control the strip from a computer, you’ll probably need the FadeCandy adapter:
https://www.adafruit.com/product/1689
It can drive any of our NeoPixel strips:
https://www.adafruit.com/category/183
and the strips with the highest pixel density are 144 pixels per meter.
60cm of 144pixel/m strip will be about 85 pixels, and each pixel can use a maximum of 60mA for RGB pixels, and 80mA for RGBW pixels. The worst-case current load for 85 RGB pixels is a bit over 5A, and 85 RGBW pixels can use up to 6.8A.
We’ve found that most NeoPixel projects can operate happily on 1/3 to 1/4 of the worst-case estimate, but that still puts the expected current load around 1.5A to 2A. If you don’t have an external power source, you’ll need to make sure your comouter can deliver that kind of current without killing a USB port.
by Mor on Sun Aug 25, 2019 4:22 pm
Thank you very mouch on your answeer
What about (https://www.adafruit.com/product/2328) led strip?
Is can be appropriate to my requests?
About Fadecandy,
I not found example, You can send me example Project samples(I happy .Net framework)?
I n this board i just connect this to my computer? I not need Create project on the board like ardunio boards?
Mor
by Mor on Mon Aug 26, 2019 9:50 am
Hi Mike,
You Can approve / reject the option of working with this strip leds (https://www.adafruit.com/product/2328) and microcontroller(https://www.adafruit.com/product/1689)?
Without any external power (Just USB)?
Mor
by Mor on Tue Aug 27, 2019 3:12 am
I want to buy a lot of units, so I want to make sure it's supported.
Mor
by adafruit_support_mike on Wed Aug 28, 2019 1:29 am
Mor wrote:What about (https://www.adafruit.com/product/2328) led strip?
The FadeCandy doesn't work with DotStars, only NeoPixels. The signal protocols for the control messages are different, and DotStars have a different number of pins.
by Mor on Wed Aug 28, 2019 2:43 am
Thank you very much.
Mor
