Run Length From Single Power Source
by jeffwillems on Tue Aug 20, 2019 2:01 pm
Hi I'm looking to use the Flexible RGB Neon-like LED Strip (linked below) for a stage design project. I was hoping to find out how long of a run of the 'neon' I could send from a single power source. Thanks.
https://www.adafruit.com/product/4245
jeffwillems
Re: Run Length From Single Power Source
by adafruit_support_bill on Tue Aug 20, 2019 2:26 pm
It depends somewhat on how hard you drive them. At full intensity on all channels, it will pull about 20W at 12v. So you would need a power supply rated for about 1.7A per meter.
If you are driving many meters from a single supply, you will want to feed power every few meters.
by bryonygp on Wed Aug 21, 2019 8:12 pm
Also a stage project in the making with about 20 sections of neon-like strips in different colors averaging 150" in length each. Questions:
- Can I purchase sections longer than a meter? Estimating a need of 150' total
- I need to fade in/out of two sections at a time. Is there a relay you recommend? Ideally automatic, but no need for extreme coding. Would rather avoid Arduino and the use of another computer/device just to run the stage decoration.
- What is the best way to end a cut strip? Can't seem to find any end caps.
Thank you!
bryonygp
by adafruit_support_bill on Wed Aug 21, 2019 8:42 pm
@bryonygp - please start a new thread for your question
posting.php?mode=post&f=47
