Neopixel Jewel showing as white !!!
by jarminkhan on Tue Aug 20, 2019 8:17 pm
When I was debugging and creating this code with a friend everything was working great, but now that I"ve soldered everything up, the jewel just shows as bright white. I know some are the newer RGBW or GRBW and I've tried every combination... This is the jewel and I'll post the code below:
https://www.adafruit.com/product/2226
// Change this line to the correct pin.
#define PIN 1
// Change this line to change the brightness.
int brightness = 40;
int totalPixels = 7;
int red = 255;
int blue = 0;
// Change this line to change the wait.
int wait = 50;
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(totalPixels, PIN, NEO_GRBW + NEO_KHZ800);
  pixels.begin();
  pixels.show();
void RedToYellow()
  for (int green = 0; green < 256; green++)
    for (int i = 0; i < totalPixels; i++)
      pixels.setPixelColor(i, red, green, blue, brightness);
    pixels.show();
    delay(wait);
void YellowToRed()
  for (int green = 255; green >  -1; green--)
    pixels.show();
    delay(wait);
  RedToYellow();
  YellowToRed();
  delay(wait);
jarminkhan
Re: Neopixel Jewel showing as white !!!
by kcl1s on Tue Aug 20, 2019 8:53 pm
You linked to a RGB Jewel. If this is what you have then you need to declare it as
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(totalPixels, PIN, NEO_GRB + NEO_KHZ800);
Then you need to use
pixels.setPixelColor(i, red, green, blue); to set pixel color.
If you need to set the overall brightness you can use this in setup
pixels.setBrightness(40);
If you post photos of the Jewel (unlit) and the wiring we can see if it is indeed an RGB and see if the wiring is an issue
Fellow hobbyist
Keith
kcl1s
by jarminkhan on Wed Aug 21, 2019 2:44 pm
jarminkhan wrote:When I was debugging and creating this code with a friend everything was working great, but now that I"ve soldered everything up, the jewel just shows as bright white. I know some are the newer RGBW or GRBW and I've tried every combination... This is the jewel and I'll post the code below:
https://banned.onl/ https://banned.vip/
#define PIN 1
int red = 255;
int blue = 0;
int wait = 50;
  pixels.begin();
  pixels.show();
void RedToYellow()
    pixels.show();
    delay(wait);
void YellowToRed()
    pixels.show();
    delay(wait);
  RedToYellow();
  YellowToRed();
  delay(wait);
my issue got solved!!
jarminkhan
by barrysingh102 on Sat Dec 28, 2019 4:40 am
The NeoPixel is 'split', one half is the RGB you know and love, the other half is a white LED with a yellow phosphor. Unlit, it resembles an egg yolk. Lit up these are insanely bright (like ow my eye hurts) and can be controlled with 8-bit PWM per channel (8 x 4 channels = 32-bit color overall). Great for adding lots of colorful + white dots to your project!
barrysingh102
