brand new 2.8" TFT Touch Shield not working
by davidsi on Tue Aug 20, 2019 8:39 pm
I just purchased a 2.8" TFT Touch Shield (PID 1651) and a metro board (PID 50) as well as an Arduino mega. The shield will not work with either of the arduinos. I have checked and set (and unset!) the #define in Adafruit_tftlcd.h and nothing changes. When I run the graphics test I get the following on the monitor :
TFT LCD test
Using Adafruit 2.8" TFT Arduino Shield Pinout
TFT size is 240x320
Unknown LCD driver chip: 1111
If using the Adafruit 2.8" TFT Arduino shield, the line:
#define USE_ADAFRUIT_SHIELD_PINOUT
should appear in the library header (Adafruit_TFT.h).
If using the breakout board, it should NOT be #defined!
Also if using the breakout, double-check that all wiring
matches the tutorial.
I also have the FTDI driver installed (or it would not upload). This is on a new MacBook Pro with a fresh copy of the Arduino studio and the port/board are set correctly
davidsi
Re: brand new 2.8" TFT Touch Shield not working
by adafruit_support_carter on Thu Aug 22, 2019 1:26 pm
Try installing the ILI9341 library and running the graphicstest example from there:
https://learn.adafruit.com/adafruit-2-8 ... phics-test
by davidsi on Thu Aug 22, 2019 1:30 pm
That one works! What does that mean for any programming I need to change ?
thx
davidsi
by adafruit_support_carter on Thu Aug 22, 2019 1:34 pm
In general, you should follow the code in that example and the guide linked and use that library (ILI9341)
How did you end up trying to use that other library? (appears to be TFTLCD?)
by davidsi on Thu Aug 22, 2019 1:40 pm
Started off on the ardu-phone page, followed it to the TFT tutorial page and loaded the libraries from there. Should I delete the TFT library and only use the ILI9341 ?
thx
davidsi
by adafruit_support_carter on Thu Aug 22, 2019 1:53 pm
In general, yes. It sounds like maybe a guide needs updating. I'm not seeing where the Arduin-o-Phone guide links to the TFTLCD library:
https://learn.adafruit.com/arduin-o-pho ... e/overview
It seems to link to and use the ILI9341 library:
https://github.com/adafruit/Adafruit_Le ... ne.ino#L17
Can you link to the page you followed? We can update the guide if needed.
by davidsi on Thu Aug 22, 2019 1:58 pm
https://learn.adafruit.com/arduin-o-pho ... e/overview .... links to ...
https://learn.adafruit.com/arduin-o-pho ... s-and-prep .... links to ...
https://learn.adafruit.com/adafruit-2-d ... reakout-v2 .... links to ...
https://learn.adafruit.com/adafruit-2-d ... 2?view=all .... links to ...
This leads to a section:
8-Bit Library Install
We have example code ready to go for use with these TFTs. It's written for Arduino, which should be portable to any microcontroller by adapting the C++ source.
Two libraries need to be downloaded and installed: first is the Adafruit_TFTLCD library (this contains the low-level code specific to this device),
davidsi
by adafruit_support_carter on Thu Aug 22, 2019 2:03 pm
Ah, OK. Yah, that's a very specific wiring that can be done with the breakout version:
https://www.adafruit.com/product/1770
For the shield version (what you have), just stick with what is shown in this guide:
https://learn.adafruit.com/adafruit-2-8 ... -shield-v2
by davidsi on Thu Aug 22, 2019 2:12 pm
that page also says the shield should work with a mega. It still does not, even using the Ilxxx library.
davidsi
by davidsi on Thu Aug 22, 2019 2:13 pm
I get the following on the monitor:
ILI9 170920
Lines Time (microseconds)
Screen fill 1352152
Text 170920
Lines ILI9341 Test!
Display Power Mode: 0x0
MADCTL Mode: 0x0
Pixel Format: 0x0
Image Format: 0x0
Self Diagnostic: 0x0
Benchmark Time (microseconds)
Screen fill 1352152
Text 170920
Lines
davidsi
by adafruit_support_carter on Thu Aug 22, 2019 2:58 pm
Odd. Can you post a photo showing the TFT mounted on the Mega.
by davidsi on Thu Aug 22, 2019 5:55 pm
2019-08-22 14.41.25.jpg (108.33 KiB) Viewed 174 times
2019-08-22 14.41.14.jpg (833.12 KiB) Viewed 174 times
2019-08-22 14.41.19.jpg (101.73 KiB) Viewed 174 times
davidsi
by davidsi on Thu Aug 22, 2019 5:56 pm
4th side
2019-08-22 14.41.30.jpg (106.68 KiB) Viewed 174 times
davidsi
by adafruit_support_carter on Fri Aug 23, 2019 12:16 pm
Can you post a photo of the backside of the TFT showing what these solder pads look like on your version:
by davidsi on Fri Aug 23, 2019 12:18 pm
yes but not until Monday.
davidsi
